Spark plugs indicate bad coils?
Old Oct 30, 2006 | 08:58 AM
wootwoot's Avatar
Can you look at your spark plugs and tell if you have a bad coil? I am replacing both my plugs and the coilpacks in the next few days and was just curious if by looking at a plug I could tell it had a bad coil in it. Hopefully this will take care of my check engine light, if not then it will be time to replace the knock sensor...
Old Oct 30, 2006 | 09:52 AM
the_3d_man's Avatar
did you have a misfire code or something or are you just replacing your coils?...Fouled spark plugs could mean a number of things... but it is safe to say that if one of the plugs is blackened that there is likely a problem with the coil not firing. But if you have a check engine light you should already know or have an idea of what the problem is. (it's when you don't have a check engine light or codes that it sucks!!)... btw... what is the problem? is the light just on or do you have problems to go with it?
Old Oct 30, 2006 | 10:15 AM
wootwoot's Avatar
I do have a misfire code. Also at times my car will shake as if it is going to stall around 1500 rpms when I am just cruising around. I am hoping to fix this and restore some performance to my maxima.
Old Oct 30, 2006 | 11:29 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
How old are your plugs? What do your plugs look like? To test the coils just take a plug you know to be good and go around to each coil individualy.
Old Oct 30, 2006 | 12:44 PM
wootwoot's Avatar
My plugs are NGK copper plugs and they have about 25k on them so I figured I would go ahead and swap them out since I am doing coils.
Old Oct 30, 2006 | 01:39 PM
Nealoc187's Avatar
SLOW
I've never heard of any direct correlation between spark plug appearance and coil problems, but what 3d man said is probably a good bet.
My coilpack problems have always manifest themselves at higher throttle positions and RPM, but that's not to say they couldn't appear under different conditions.
mvm062
Nov 30, 2020 09:00 AM
PH98I30
20
Mar 25, 2020 03:44 PM
knight_yyz
Nov 6, 2015 02:34 PM
JoshG
51
Sep 21, 2015 10:41 PM
ballerchris510
Sep 11, 2015 05:29 PM
