anything bad about adjusting your idle down to 400rpm?
Old Oct 31, 2006 | 01:37 PM
Weimar Ben's Avatar
Helicopters! Money!!!
I was adjusting my idle on my 95 max today. The lowest rpm that is smooth is about 650, but I'd kinda like 400rpm for when I sit in traffic. Is there anything bad, other than vibration about setting it at 400rpm?
Old Oct 31, 2006 | 01:53 PM
nick's Avatar
why do you like it at 400rpm's ?
you car might stall in traffic with idle that low
Old Oct 31, 2006 | 02:54 PM
loverholic's Avatar
iAMIXAM!
if 650 is the smoothest, why would you like sitting in traffic feeling the vibration when you can sit smooth at 650....
Old Oct 31, 2006 | 03:30 PM
Apparition's Avatar
Ichiban King
yeah and it isn't that smooth to begin with.. and everything's in great condition on mine.
Old Oct 31, 2006 | 03:34 PM
njmaxseltd's Avatar
Low idle speed can cause a stall condition, excessive load on the electrical system because the alty isn't spinning fast enough to provide enough amps, low oil pressure because the oil pump isn't pumping at the correct speed, unefficient A/C operation, agian engine speed is key here.
Also, a setting of 400 RPM's is going to make the IACV operate in a wide open state because the ECU will be constantly trying to correct the low idle speed. Poor coolant circulation can lead to overheating, again pump speed is key to engine speed.
There's a reason (or many) why your car's idle speed is spec'd to be 650 RPM's.
Old Oct 31, 2006 | 03:41 PM
Apparition's Avatar
Ichiban King
..speaking of that, does your cars int. lights dim a bit when you put your foot on the brake?
Old Oct 31, 2006 | 04:27 PM
scrhale's Avatar
mine do ... annoys me. I think it is grounding though.
Old Oct 31, 2006 | 07:16 PM
Weimar Ben's Avatar
I have a battery from costco that does 900cca and has top and side posts. I ran a 4ga ground wire from the neg side post to the IM. It starts up much easier since I did that. It now starts up with one turn of the crank on an engine that has 200k miles on it.
Old Oct 31, 2006 | 07:43 PM
Jellyfishian's Avatar
Difficult is NOT impossible!
mine do too, even the headlights a little bit..
Old Oct 31, 2006 | 08:51 PM
tranz's Avatar
stupid question but is it hard to adjust idle?
Old Oct 31, 2006 | 09:48 PM
Apparition's Avatar
Ichiban King
nope.. 10char
Old Oct 31, 2006 | 10:08 PM
Weimar Ben's Avatar
After car is warmed up, disconnect tps, turn screw on IACV.
Old Oct 31, 2006 | 10:57 PM
mastercater7's Avatar
VQ35 FTW
Thats yalls alternators. mine did the exact same thing.
Old Nov 1, 2006 | 04:33 AM
njmaxseltd's Avatar
Nope, and I'm going on 7 years with the original battery.
Idle speed is around 750, with a/c on it's almost 900.
Plenty of engine RPM's to make all my engine components run correctly, especially under a load.
Old Nov 1, 2006 | 06:32 AM
Flava_24/7's Avatar
Boosted Panda
You can fine tune like that, but it should be done at the TB.
Old Nov 1, 2006 | 07:30 AM
HomerMAC's Avatar
Donating i30 Owner
i stalled when i 1st got the 5th gen clutch and pressure plate.... apparantly it grabs alot harder than i thought...
and why would you want to your to vibrate that much.. and i think NJMAXSELTD covered it..
Old Nov 1, 2006 | 07:36 AM
Great...
Old Nov 1, 2006 | 09:53 AM
Weimar Ben's Avatar
It doesn't vibrate all that much. Anyways, I figured out that anything below 500rpm won't work well, the biggest problem being parking in a parking lot, the PS will cause it to almost stall. I have it set at about 650 now.
Old Nov 1, 2006 | 03:47 PM
Fr33way™'s Avatar
Wild for Width
Very good info Tom.
Old Nov 1, 2006 | 10:53 PM
VQ35 FTW
Originally Posted by Jellyfishian
Great...
ya but good news is it aint to hard to replace, and so you know, i drove on a bad one for 1 year. so you dont gotta rush to fix it.
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
