Car not starting after some repairs,
Old Oct 31, 2006 | 09:12 PM
nitink's Avatar
Car stalling now, after some repairs,
Update 11-01-06
Thanks Guys,
Today I removed intake, retighten TB & found a vaccume tube broken, I replaced that and Now car is starting, but stalls Immediatly, if I keep giving gas it will keep running, but if I stops giving gas it stalls.
Can TPS cause this? Please tell me what should I look next,
10-31-06
Over last 4 days I did some minor repairs and now car is not starting, The key is crancking, I hear some rattling noise and then a noise like some air pressure is released and then dead. car does not start, any idea how can I rectify this.
I did following before car stopped
0) removed intake, sprayed QD electric cleaner on MAF housing.
1) Remove throttle body (cut coolant line & replace it)
2) Replace TPS, I just removed old TPS & put in new one, no other adjustments
3) Replace throttle body gasket.
4) thoroughly cleaned up throttle body.
5) took out battery cable, tried to remove starter, but it didn't come out so I unscew two bolts r back, sprayed some brake cleaner and after 3-4 minutes sprayed lot of lithium grese. put back the bolts.
Please help
Old Oct 31, 2006 | 10:25 PM
spadez911's Avatar
i would check my starter again and look into testing the MAF first
Old Oct 31, 2006 | 11:02 PM
mastercater7's Avatar
VQ35 FTW
it has somethin to do with your intake, its not the starter if it clicks
Old Nov 1, 2006 | 04:51 AM
MaximaSE96's Avatar
Maxima Owner
well u could have killed ur MAF but it would usually still start just not accel past 2k cause u should use MAF cleaner to clean the MAF.......your TPS might need to be adjusted but again the car should still start......so check all ur connections even battery voltage i might have drained it
Old Nov 1, 2006 | 01:03 PM
nitink's Avatar
Does changing TPS can cause Stalls after start
Nitin
Old Nov 1, 2006 | 01:34 PM
jos's Avatar
jos
Check out a manual for adjusting the tps. I recall something about measuring the resistance at the tps with accelerator at normal closed position and then as you open the throttle.
Old Nov 1, 2006 | 01:53 PM
RichMax's Avatar
Boosted like Snipes tax refund
I have had this exact problem. I believe the MAF shook loose from the intake and possibly got disconnected in my car. I also happened to have a dead battery due to other circumstances. After a few days I replaced the battery and plugged in the MAF. Either all the problems were related or my MAF went temporarily dead for some reason. I think the problems are traceable directly to your MAF based on what you are describing, which is EXACTLY the problem I had.
One last thing. The other starting problem you described sounds like your starter tried to engage but did not have enough juice. Happens to me all the time when I disconnect my battery and later fail to tighten the terminal posts enough. Try tightening them up onto the battery.
Do you have a CEL?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
ZerotoSixty
Aug 6, 2015 04:34 AM
