Idle Issues
Old Nov 2, 2006 | 06:17 AM
BlackMaxdout's Avatar
Idle Issues
First off, I just want to say that I am using a friend's account to post this since mine isn't working.....
Anyway, I have a 98 Maxima SE 5 speed and recently started noticing a jumpy idle. On my way to work the other morning, I came to a stop at a red light, car in first with my foot on the clutch (obviously). My car usually idles at around 700 or 800rpm, but it jumped up to around 1500+ rpm then back down to about 1000. I knocked the car into neutral to see if that would stop it, to no avail. The car runs fine otherwise (no misfires or anything like that). I haven't owned the car for very long and haven't driven it in the cold yet, but part of me definitely thinks that there is something going on. A few of my friends have mentioned the possibility of the IACV or the TPS.
Has anyone else had this problem? If yes, what did it end up being? Any advice would be helpful. Thanks!
-Kimmy
Old Nov 2, 2006 | 08:18 AM
Cdg2125's Avatar
Did you try adjusting the screw yet?
Old Nov 2, 2006 | 09:30 AM
No, not yet. I just bought the car about 3 months ago and this just started a day ago.....I'll give that a whirl.
Old Nov 2, 2006 | 08:02 PM
jojo98maxima
i think that is that answer to ur trobles
Old Nov 2, 2006 | 09:36 PM
steven88's Avatar
Need A Light?
I worked on a 4th gen with a similiar problem...I cleaned his throttle body and did a full seafoam treatment...it cured all his problems...
SeaFoam for teh win!!
Old Nov 2, 2006 | 09:37 PM
Mass_Media's Avatar
Mass_Media™
how does seafoam work? any special instructions....
Old Nov 2, 2006 | 09:41 PM
steven88's Avatar
Need A Light?
theres a few threads in the fluids and lubricant section...check them out...also you can run a search, since your a donating member...
Old Nov 2, 2006 | 11:30 PM
Cheeshead's Avatar
I've cleaned the TB, tried adjusting the idle, changed the plugs and have also checked all the coil packs. Nothing works.
I am getting a code from the TCM, 3rd flash longer which should be the Throttle sensor, is that the same as the Throttle position sensor?
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
ballerchris510
Sep 10, 2015 09:35 PM
