Compression Test Results
Old Nov 4, 2006 | 02:02 PM
speed racer's Avatar
I did a compression test today. Tell me what you think.
Cyl. 2 195 PSI
Cyl. 4 185 PSI
Cyl. 6 190 PSI
Cyl. 1 200 PSI
Cyl. 3 185 PSI
Cyl. 5 190 PSI
I have 146,000 miles on the car.
Old Nov 4, 2006 | 02:56 PM
JwaxMax99's Avatar
You are in fine shape. 185 is standard and minimum is 142.
Mind you these specs are measured at 300 rpm.
But your max. cyl. differential is at the limit for factory spec. (14 psi.)
Old Nov 4, 2006 | 03:14 PM
dgeesaman's Avatar
Maintenance Monster
Related question:
I've heard about draining the oil and filling with 2qt new oil and 2qt ATF. Start the car and let it idle for an hour or so. Then drain and put in all fresh engine oil. The idea is that the ATF cleans out things and improves the compression and loosens deposits on the pistons and cylinders.
Good idea?
Dave
Old Nov 4, 2006 | 04:21 PM
Haven't heard about this one. I use amsoil synthetic. Been using it since I got the car at 117k.
One thing I did notice is that cly. 2, 4, and 6 all had some minor oil on the threads. where as cyl. 1, 3, 6, had hardly any. Cyl. 1 looked like it never been used. Thats the one with 200 psi.
Old Nov 4, 2006 | 04:42 PM
f550maranello2's Avatar
i have heard about that.. i wouldnt do it though cuz ur bearings arent gonna like that..
Old Nov 4, 2006 | 05:13 PM
1chewabacha1's Avatar
You're fine. 185 is the norm with a max variant of 15.
FYI mine was 195 - 200
Old Nov 4, 2006 | 07:42 PM
dgeesaman's Avatar
Maintenance Monster
That's why you still use some regular oil and only idle it.
Dave
Old Nov 4, 2006 | 08:39 PM
EnervinE's Avatar
i has college
Yeah, I'd think idling the car for an hour would hurt more than it fixed
Old Nov 5, 2006 | 12:12 AM
Godson's Avatar
Man you gotta love these VQ's...did mine last week with 195-200psi all around...110,000 and I beat her death most of the time,but apperently she likes it rough
Old Nov 5, 2006 | 02:02 AM
Cdg2125's Avatar
How do you test?
Old Nov 5, 2006 | 06:25 AM
To test all you do is remove the fuel pump fuse. Relieve all the fuel pressure by cranking the car until it dies. Than remove each spark plug. Place the compression gauge into each cylinder. Crank the car 5 times to get accuracy. Each time its cranked the pressure goes up.
When I first read the instructions I thought you needed two people to perform the test. But that is quite the contrary. This can be done by yourself.
Old Nov 5, 2006 | 08:47 AM
Cdg2125's Avatar
ok thanks. I'll look into doing this.
Old Nov 5, 2006 | 08:48 AM
dgeesaman's Avatar
Maintenance Monster
I forget - should all the plugs be out at the same time, or just the one replaced the tester?
Old Nov 5, 2006 | 09:43 AM
djfrestyl's Avatar
Suspension Yoda
Just the plug of the cylinder you're testing.
Old Nov 5, 2006 | 09:53 AM
^^^ Yep. The instructions say to take all of them out, but I believe taking one at a time is recommended.
Old Nov 5, 2006 | 12:24 PM
dgeesaman's Avatar
Maintenance Monster
Also worth noting - the engine should be hot. Cold engines produce artificially high compression.
Dave
Old Nov 5, 2006 | 07:02 PM
Godson's Avatar
Dave
Lol..yea I found that out the hard way...
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
