Bosch Plat vs NGK Plat Plug?
Old Nov 6, 2006 | 03:51 PM
maxman92's Avatar
Ok I just picked up my 98 se and the previous owner installed a set of Bosch plat plugs right before he gave me the car. he said the plugs where original and was trying to be nice and change them for me.
The car has 85k on it and i was just wondering will the Orig NGK Plat plugs at $10 - $15 a plug make any kind of difference (gas milage, performance)?
The gas milage isnt that great to begin with and i have already cleaned the TB and IACV. I have also Seafoamed. The car idles very well i would just like better gas milage. My next step was to clean the MAF.
Just wanted to make sure it was worth all that extra money for the plugs. And what kind of difference people saw from cheap plugs to the NGK Plat plugs? Also what did you use to clean the MAF?
Thanks in advance for all your help!
Old Nov 6, 2006 | 03:57 PM
mastercater7's Avatar
VQ35 FTW
I have NGK iridiums and saw a difference only cuz the old plugs were so horrible. however, its probly ur knock sensor
Old Nov 6, 2006 | 03:59 PM
f550maranello2's Avatar
our cars ONLY like the NGK.. get the platinums
Old Nov 6, 2006 | 04:04 PM
MaximaSpd85's Avatar
if u dont wanna cough up $60+ for plats, u can get NGK V-Powers for about the price of one platinum.
Old Nov 6, 2006 | 04:18 PM
moogotzskillz2's Avatar
I dont know if its from the bosch plugs, but I know that Bosch isnt really good for Maxima's and that it might give u a misfire. so i'd say go back and get u the NGK V-power(if u dont wana spend that much) and it will run better.
-moo
Old Nov 6, 2006 | 05:11 PM
2da mizzax's Avatar
only use dealer plugs. and wahtever you do NEVER use bosch. they are crapola. poor mileage. poor power. and they will burn out or break in little or no time.
Old Nov 6, 2006 | 05:16 PM
matrix11229's Avatar
According to NGK website, there is no difference in performance/gas mileage between different brands and types of plugs.
Get the NGK coppers at Strauss, they cost $12 per set of six. They will last for 30k miles.
Six month ago I wanted to replace the old NGK platinums, and bought Bosch platinum+2 plugs. My engine strated vibrating in D and N so I had to return them for a refund and bought the Ngk V-power copper plugs and they make the engine running very smooth.
Old Nov 6, 2006 | 05:21 PM
Cdg2125's Avatar
Should have just looked at the maxmods and stickies....it's your car and wallet...buy the plugs you want.
Cleaning the maf you need electrical cleaner stuff. Cant remember the actual name tho.
Old Nov 6, 2006 | 05:43 PM
maxman92's Avatar
Its not my knock sensor. I checked for codes and resistance. I kinda figured the NGK Plat plugs would be better. I guess I just needed to hear it for myself.
I dont mind spending money as long as its worth it. Nothing worse then throwing your money away on crap that you dont need or dont work. I believe in buying the best the first time instead of buying crap 10 times.
Old Nov 6, 2006 | 05:54 PM
95 maxima se's Avatar
Silver Tooth S2K 9k FTMFW
talking about bosch platium 2's, they suck a$$!!! Dont buy them! im getting a misfire, im gonna buy some NGK's this weekend
Old Nov 6, 2006 | 06:13 PM
NmexMAX's Avatar
dot dot dot ...
Cu NGK, $1.98/plug, NAPA, Nissan dealer, .
Old Nov 6, 2006 | 06:20 PM
heynow's Avatar
Get NGK Plats PERIOD!!!
Old Nov 6, 2006 | 07:17 PM
cam_honestiam's Avatar
I have had NGK plats and NGK Irids. I notice no improvement in the irids over the plats, and over time, I think I am actually noticing a decline. I will get plats next time, if there ever is one.
The electrical cleaner is CRC eletrical parts cleaner I believe. Get it at AutoZone, Checker, Kragen, Advance, NAPA.
motocross416's Avatar
NGK
I had bosch, switched back to NGKs and there was a noticeable difference
Old Nov 9, 2006 | 09:26 AM
jjamzman's Avatar
It must vary from car to car because I have run Bosch plats for over 100K with none of the problems mentioned. I have great power and 25mpg, and I have 218K on this Max. Next time I will try the NGK's but have no reason to switch until the current Bosch units wear out.
jjam
Old Nov 17, 2006 | 06:01 AM
JohninSC's Avatar
All the anti-Bosch comments sound like a superstition to me!
I'm on my second set of Bosch plugs. Car runs just fine.
My car's (95SE) original OEM NGKs were on the way out at 55k - earlier than the recommended life of 60k. The first set of Bosches made a huge improvement - probably since the old NGKs were worn out. So, I stayed with the Bosch plugs a second time. I used the +2 and changed them at 30k only because I wasn't sure what their lifespan would be. They looked and drove fine but since I had them out, I replaced them. Not expensive.
Old Nov 17, 2006 | 06:22 AM
Bobo's Avatar
I've got 66K on my original laser platinum plugs and I have had the car 12 years. The car runs like a champ and I can get over 500 miles to a tank of gas on a road trip consistently.
There have been a gazillion threads about Bosch plugs before. Get rid of them. They are more suited to European cars.
I will replace my plugs before I go through emissions testing next December at which time they may have 72/73K on them. I know someone with over 90K on his OEM platinum plugs for his 99 Maxima and his car still runs fine.
For my money, I will use OEM laser platinum plugs and forget the cost savings of buying V-power coppers. I would have been on my 3rd set of V-powers by now.
For those using Bosch plugs, you might as well use Fram oil filters and crappy oil while you are at it and don't forget that 87 octane is best for your Maxima.
Old Nov 17, 2006 | 06:27 AM
Capital15's Avatar
I have never install any other plug other than NGK....running the Iridiums right now. Car is fine...smooth...can't complain.
Old Nov 17, 2006 | 11:05 AM
oVeRdOsE's Avatar
You make me scared. I run on Bocsh Platinium 4+ since 20 000 km ,and Ive no problem. Its so smooth.
So, should I get to NGK?
Old Nov 17, 2006 | 05:11 PM
andrei3333's Avatar
how do i know my plugs need to be changed ? i have no problems with accerelation or anything else engine related, no knocking, car is a 97 with 204KM on it, bought it used dunno if plugs were ever replaced
i get 550 km / tank of gas a mix of hwy and city driving, so what are the signs of worn out plugs
also it seems hard to change the back ones how are they changed ?
thanx
Old Nov 17, 2006 | 05:36 PM
PLUMMAXSE's Avatar
Don't forget your O2 sensors as a possible culprit for lowered gas mileage. A 98 Max with 85k on the clock could use some new sensors. Remember the O2 sensors relay info to the ECU about how much fuel to burn. Slow responding O2 sensors = Low mileage especially in the city. The 2 upstream ones in the Ypipe are the ones to replace first. The one in near the converter doesn't effect mileage.
Old Nov 17, 2006 | 07:51 PM
kingjon's Avatar
NGK Laser Iridiums..
Old Nov 17, 2006 | 08:46 PM
96blkonblkse's Avatar
my original plugs were replaced at the 60K service, but from there till 180K miles they were never replaced. I didnt find that out till i started to get a really bad misfire in the mid-high rpm range, it got worse then when i pulled the plugs are realized the condition of them i knew they had not been replaced in along time. According to the service history from the previous owner it was replaced at the 60K and never from then. The electrode on the plugs had worn down so much there was about a 1/4 to 3/8" gap. I replaced them with OEM NGK PFR5G-11 pre gapped and i noticed a few of my problems went away, hard starting when cold was one of them and the revs dipping low when i came to a stop with the cltuch in.
Old Nov 18, 2006 | 06:13 AM
Bobo's Avatar
There are write ups on how to change the plugs. Check the stickies and www.motorvate.ca. Also you should buy yourself a Haynes manual.
To determine if your plugs need to be changed, take one out and look at it.
At 204,000 kilometres, I suspect your plugs have been changed before. The question is: what plugs are in there now?
By the way, 550 km/tank for a mix of highway and city driving is nothing to write home about. You should be able to get 550 km/tank with straight city driving if you don't drive the car like you stole it.
thanx
Old Nov 18, 2006 | 07:44 AM
maximariceboi's Avatar
i been using the bosch plat +4..been in the car for about 2.5 years already..no problems with them..i had iridiums on my other max but they got burnt out because of misfire/eu problem
Old Nov 18, 2006 | 06:16 PM
I finally got 587km to a tank, mostly city and a bit of highway (made a few trips to richmond. Did i mention i put an additional 20$ worth of gas, so in total i put in 82 liters to get a measily 587km to a tank. Usually i can barely muster 470-480km.
Old Nov 18, 2006 | 10:47 PM
andrei3333's Avatar
http://www.motorvate.ca/mvp.php
this site has nothing on spark plugs, the forums are offline
Old Nov 19, 2006 | 06:07 AM
Bobo's Avatar
Buy a Haynes manual, or if you are too cheap to do that, go to your local public library and if they have a manual borrow it and if they won't let you, then photocopy the relevant pages.
Did you check the stickies?
Old Nov 19, 2006 | 06:10 AM
Bobo's Avatar
That is pathetic fuel economy! Are you showing any codes?
I wonder if your knock sensor is toast?
When was the last time you used any fuel injector cleaner?
Have you replaced your PCV valve and the fuel filter and air filter at any time in the recent past?
Old Nov 19, 2006 | 06:29 AM
natty99's Avatar
GEE-ZUS, here we go again with these threads knocking the Bosch platinums. I understand people have their negative expereinces, but damn people, others have had good expereinces with them as well. My dad has been using Bosch platinum +2 in his 95 max for as long as I can remember, def the majority of the car's life thus far (he bought it new, it now has 205K miles). Gets like 31mpg and car still has good power. Never had any problems associated with them. I use Bosch +4 in my 98 max and get damn good power too. No problems after the 30K miles I've put on them thus far.
Get what you want, but don't get scared into thinking your only choice is NGK plats or merely just NGK plugs. I swear, it's like some guys on this site have stock in NGK or something....
TKHanson
Nov 24, 2018 01:39 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
