ignition coil input wire?
Originally Posted by babymac
Harlen..........but I mean which color wire on the coil? well the harlen too??
Not sure which exact coil wire to use, but you should consider the Summit switch. Many have had issues with the Harlan flaking out on them. Sometimes it works, sometimes it doesnt. Too much of a headache.
I tried sarching but no one stated specifically which one it was. i do know that if you decide to get the signal from the ecu its the white wire with a green stripe. Its buried in the mess of wres at the harness plugging into the ECU.
The TAM screw is just that. There is a phillips head screw on the back labled TAM you can unscrew it and use a ring terminal on your new wire..... to bad neither my 98 cluster and SEL cluster have it!
Nope............
If so then the gain your feeling is not from the MEVI then, its the ecu, especially if your not feeling any power loss.
There is no power gain from the MEVI if your running it closed.
I have my MEVI wired up to the TAM screw on the back of the cluster, although Im using a Summit switch but I dont see why it would matter. I do know that the Summit switch doesnt work using a coil wirefor RPM signal though.
Originally Posted by Flava_24/7
Are you running an upgraded ECU?
and yes I am going to use the tam screw.
James92SE
142
Jan 2, 2024 09:23 AM
The Frye
Sep 2, 2021 11:03 AM
