View Poll Results: Radiator support rust repair
Fixed with new support!
31.40%
Tried to weld in a piece of steel (cheap fix).
14.88%
Letting it ROT till the engine falls out!
25.62%
Engine fell out! Dag!
2.07%
What do you mean? Mine is fine!
26.86%
Multiple Choice Poll. Voters: 242. You may not vote on this poll
Quote:
Originally Posted by matty
......I said "it is a Tie Rod Support or something along those lines".............>When did I ever say "It is a Tie Rod Support" ?? .............-matt
hhmmmmmmSenior Member
Quote:
werd yo, my unedumacated self would just calls it "the lower part" that's the mad technical term they used when i bought it. tie rod support is way off, what a dolt that **** is Originally Posted by 2da mizzax
perhaps you should shut the hell up until you read and see that he called it a tie rod support you dolt. you know-it-all's kill me. if you had half a brain you would have been able to sense the sarcasm.
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
dolt
it's kinda tought to "read" sarcasm, so i figured i would exagerate it.Well if I may speak in part of anyone who still needs it fixed, THANK YOU to everyone so far who has helped by adding part numbers, prices, diagrams, contacts, pictures, or any other info.
This is an issue with everybody in this forum's car who lives where weather is an issue and it is much appreciated. I, as well as many others are on here are here to give help and receive help whenever possible or needed. I always try to help when I know about a problem posted, but sometimes, like with this issue, I am clueless and need the expertise of my brothers (and sisters as well) in the .org community that have had experience with this DREADED issue.
This rust is my biggest problem with my car right now (and I KNOW others' too-Damn OCD!) so aside from the small amount of bad posts, there is now a nice little gathering of valuable and useful information which desperately needed addressed and added to our library.
Thanks again to all who contributed so far and in the future to this thread. It is very useful to all of us here, and anyone in the future.
Well, mine is really bad. What I am thinking of doing is buying this piece, http://cgi.ebay.com/ebaymotors/ws/eB...3841832&rd=1,1
I plan on cutting the old one off about 4 inches from the very end of the support and splicing this one in. I would like to do it myself but it looks like it really needs to be on a lift and the front mount needs to be supported while the old one is taken out. The garage plans on using a sawzall to cut it apart and clamp and weld the new one in.
My main question is should I spend more money and just get the lower support and have it replaced? I think the above method splicng it in would be less costly and work just as well.
from what i have seen aftermarkets usually come thinner and break faster. but i guess it varies with each manufacturer. had one break that wasnt even rusted out. i would get a new one from the dealer. put some POR-15 on it and never think about it again.
why would they want to wend around a 4 inch tube when they could drill out the factory spot welds and weld it into the same spot, alot less work and neater too. i would go to another shopOriginally Posted by cpt
Well, mine is really bad. What I am thinking of doing is buying this piece, http://cgi.ebay.com/ebaymotors/ws/eB...3841832&rd=1,1I plan on cutting the old one off about 4 inches from the very end of the support and splicing this one in. I would like to do it myself but it looks like it really needs to be on a lift and the front mount needs to be supported while the old one is taken out. The garage plans on using a sawzall to cut it apart and clamp and weld the new one in.
Because you have to take everything off the front to get to it. He thinks he can do it in less than 2 hours. BTW, you may think this is a hick butcher but he is a local guy who has had a garage for 30 years. I've seen his work and its great. It's a 96, I won't have the car for more than 5 years.
Quote:
whatever floats your boat. i work on the autobody industry and i see plenty of hacks that have been doing it for 30 years. you have to take out the radiator and the condenser anyway,unless you want to cut them up, afte that what's left? the bumper and lights? that i can have off in less than an hour. an hour is worth not hacking a car up. if you said you wont have the car more than 5 months its one thing, but 5 years............. just do it right.Originally Posted by cpt
either way you have to take off the bumper and support behind it to do this. its not like you have to remove the headlamps and fenders.
in order to take off the bumper you have to take off the lights, the upper retainer bolt is under the headlightand corner light. you only have to take off the fenders if you're changing the whole support., like this:
Good thread, I have this same problem. Is there any way to seal out moisture at the bottom of the support after you spend money on fixing it?
Edit: nevermind, I missed page 2
Apparently it's not just 4th gens. I just spent $1209.07 two weeks ago to replace the lower tie bar (radiator support) and engine mount at a bodyshop for my 2000 SE. The support was so rotted out that my engine mount was disconnected, causing the engine to thump around when driving.
Thanks for all the info everyone. After considering my options of the whole support and just lower bracket I opted for the cheap steel weld solution. Didn't realize my problem til I had to replace my K40 remote radar mounted there and saw the rust on mine. Mine was about 25% rusted through with one bolt holding well and the other only a little (10yrs 127Kmi). After chipping away the loose rust and treating they welded a 1" x 2" x 1/4" steel L bracket onto the crossmember.
$9 for the steel, 1 hour labor. Subframe connector is now permanently in place so we'll have to cut it to remove the tranny or engine if ever needed. If that day comes then I have more to spend than breaking a weld.
Quote:
I think that it is a really bad idea to weld the brace to the frame. Other members have had this done, and the weld broke. PLUS what a huge PITA when you change your clutch. If you have an auto tranny, than I guess that it is not so bad.Originally Posted by BEJAY1
I hope it works out for you, and your tranny last a long time.
Quote:
no offense, but i can see right through that caked on paint/undercoating and can see the hack job under that. at the very least you could have had someone bend you up a piece of say 1/8 inch plate to the same shape, put it where it should go, mark out the crossmember mount holes, cut them out, weld a nut on the other side of the plate, weld the plate solid on the lower support. still a visible repair, but it retains all the functionality of the oem design. it looks like they welded the L channel to the crossmember, then tacked that onto one side of the support. the welds on the support dont look like they penetrated.Originally Posted by BEJAY1
I just cut/ground mine out the other day, I was planning on replacing just the lower as it was HORRIBLE, but then I got in a little accident. Figured I'd add some pics and comment on the ghettoniss of the repair above.......
Quote:
Yup, and it really wasn't that bad. I mean the welds aren't pretty by any means, but it's deffinitly not going anywhere, even if there wasn't three huge bolts on each side. I actually had to have an entire front cut out of a car just to use the upper section's, they wanted $400+ at the dealer!! I'm gonna throw some pics out up.Originally Posted by happy4444
damnnnnnn... did u end up putting in an ertire support urself??
In this pic if you look closely you can see the three steps to drilling out the pinch welds, I found this to be much easier than grinding them out. step #1- Center punch. #2-pilot hole. #3-ummm, maybe 3/8 dril bit, don't remember, but big enough to cover the pinch weld and then some.
Finished, finally, after 30+ holes just to use this upper off of a junkyard entire support.
Clamping the new lower in place, before installing the 3-bolts and tow hook plate.
STEP #1 BEFORE WELDING!! I mean seriously, why would you not do this, it takes ten seconds, if it takes you longer than 20 seconds then it will take you about 8 hours just to remove the ecu and replace it with another one, I could drop a VQ quicker than I could pull an A32 ecu, seriously. Overboard, NO, it really only takes 2 seconds, DO IT, as well as disconnecting both battery terminals, just DO IT.
Obviously, I've left out a LOT of steps, this isn't really a write-up by any means, there was a lot of 'stuff' to remove obviously, plus lot's of grinding down to bare metal before welding, than cleaning up the welds and painting it all with primer than white. I'm upset right now, I lost the link to an AWESOME 101 site on mig-welding, it really was better than anywhere else, oh well, here's another one...... http://www.millerwelds.com/education...articles8.html
Quote:
rust issues and safety issues are 2 different animals. you show me an american car from the early 70's(or 80's) that folds like the ones that do nowadays. cant find one that i know of. most transfered energy very well, which means that an offset front hit would cause damage to the opposite rear quarter panel. instead of stopping that enery it traveled through the occupant. but beaing as you dont care about safety and have disabled your airbags and dont wear your seatbelt, the use of high strength steels in the frame rails to absorb that energy probably have no effect on you. check out www.iihs.org if you want to know about safety.
here's a full frame big strong truckhttp://www.iihs.org/ratings/image.ashx?rh=54&id=1
and here's your maxima:http://www.iihs.org/ratings/image.ashx?rh=43&id=1
and a 97+ http://www.iihs.org/ratings/image.ashx?rh=89&id=1
if you read the ratings i think i'd rather be in a 97 maxima.
on the issue of rust.............................show me any american car ever built before 1995 that didnt have some rust somewhere and i have a bucket full of cash for you. aint gonna happen. they were all rust buckets. what good is the frame being solid if the thin metal that holds it to the body is rotted and in a crash it rips away from the frame? and you have to compare apples to apples. full frame vehicles use 1/8 inch plate to make frames. the unibody frame rails on your car are 18 gauge at best. you think that rust is going to go through metal 4-5 times thicker that fast? and being as that you brought up pathfinders, i bought a 95 for a project that has swiss cheese for a frame. i actually put my thumb through sections of it. is that truck safer than my maxima?
any 2004 maxima and 2002?-up altima has a plastic support. the current quest and murano has a plastic support. audi 's done it since 2000 i think, volkswagen's last golf/jetta had them. obviously the crashworthiness of the support isnt as important as the frame rails and bumper reinforcement around it.
Originally Posted by shavedmax
so YOU didnt spend 25k on that car, but can't justify the cost you did spend on it because the lower part of you radiator support has some rust? you do realize there's more to a car than whether it rusts or not that determines it's cost right? at 277k you got way more than average joe gets for their car. automakers know that on average a car doesnt last over 10 years. wether it be the american way of having the newest coolest thing out there, accidents, mechanical breakdowns, wear and tear, thefts, etc etc, the avg car doesnt last that long. some people keep their cars longer, some shorter, but it averages out. how many 3rd gens do you see on the road compared to 4th gens? how about 2nd gens? gotta be a reason why right?rust issues and safety issues are 2 different animals. you show me an american car from the early 70's(or 80's) that folds like the ones that do nowadays. cant find one that i know of. most transfered energy very well, which means that an offset front hit would cause damage to the opposite rear quarter panel. instead of stopping that enery it traveled through the occupant. but beaing as you dont care about safety and have disabled your airbags and dont wear your seatbelt, the use of high strength steels in the frame rails to absorb that energy probably have no effect on you. check out www.iihs.org if you want to know about safety.
Got to agree on the safety of ours cars
before i move to the US i was living in Puerto Rico and was the owner of a 97 GlE one night i was running against a Mazda 6 and because of an idiot that changed lanes just in front of my i hit his car at 90 mph without even hitting the brakes
a 92 mirage his car went from left to right like 3 times i got out of the car without even looking at mine so i went to see how they where thanks God everyone was ok when i look at his car the trunk disappeared basically the car shrunk like by 45% even the back was pushed all the way touching the front seats so went i went to see my car i was so surprised that the only damage was the front bumper that had like 5-6 rips like 2"wide by 7-8 " long the grille was broken but nothing noticeable from 5 feet or so one headlight with a small crack like 2" long the paint was chipped from hood but wasn't bent and a blown headbulb
after that i took my car to see whether or no it was bended because of the impact and yet another surprise it was up to specs so basically i replaced the headlight bulb and ran the car for another year or so without ever noticing something wrong with it
been invloved in too many accidents and all of them at lower speeds with orse results
like
1980 200sx-new bumper new grill new hood new lower valance all four headlights radiator
1989 isuzu tropper-1 fender i door all the suspension brake for driver side even the dash was cracked
and the most funny of all a military hummer(i was driving) new grill guard new hood new radiator plus 1 month of pay hahaha
http://forums.maxima.org/showthread.php?t=404531
Link to pt 2 of the core support thread (getting fixed)
Edit: Link fixed so now the semi-writeup of core support being fixed is accessible again. (Thanks scooby68!!)
Holy Rusted Nuts Batman!
On top of my other issues to fix water pump, KS, EGR diagnosis, I just discovered the Radiator Support going south on my 97 SE, being a skier on the east coast( New Jersey) Most of my travel is on salty winter roads. Not good! Tfvesquire does repairs for members in Chicago area. Does anyone know of someone similiar on the east coast? Thanks for you replies! Vince
DO NOT spray a rustoliem product on this, it will seal the rust inside and rust even faster underneath the paint. i have seen many orgers post about this over the last 2 years and your better off not messing with it until your ready to replace.
Heres my New Radiator support installed after the old was cut out
that looks really good...
had my lower support replaced in the fall, after running with the angle iron fix for a year... scary, it came out in 5 peices.
$250 parts and labour
Originally Posted by Pimpmobile
had my lower support replaced in the fall, after running with the angle iron fix for a year... scary, it came out in 5 peices.$250 parts and labour
That is very cheap you got the hokk up hook up. lolMy labor was around that price.
But I used an oem nissan lwr rad support though
I'm having rust issue as well and am planning to replace the entire radiator support. Is the entire support bolted and removable with metric tools or are there welds I will have to cut through?
First off, its welded in.
Secondly, do a search. You couldve easily come across Shortyblue's replacement forum, and many others whose screen name escapes me right now . . .
Getting ready to finally drill mine out tonite. wish me luck!!
Quote:
the answer to your question is answered several times in this thread
Thanks, I was reading on another site and someone mentioned it was not welded if the entire support was taken off. Anyway, I know better now as I spent most of the day removing the support cuz of the welds. I could have finished this by now except I bought the aftermarket support and the fit wasn't right. It was smaller and the holes didn't align. The thin metal actually tore and rippedcas I was trying to fit it into place. I'm going to get the original from the dealer now, they want $350 for the entire frame support
Thought I had a bad axle, cause when I made a right hand turn the right front would pop an make noise. Took it in an the T between the wheels was rusted completely through where if you made a fist you could put it between all 3 supports. Had it welded an fixed up for $325 now car handles, accelerates an turns like when I bought it.
150k on the car atm, an hoping to make it to 200k at least.
Here is a photo of my rust. I did not realize how common this was. My 1995 Maxima has 160K miles and not sure if I should get rid of the car or try to fix it. I have a very short commute and don't drive more than 200 miles a month. However, I have a fear of driving down the road and hearing my engine scraping against the pavement. Being how little I drive the vehicle, does the angle-iron fix seem appropriate?Thanks
Donating i30 Owner
... i love when you guys get so passionate....
Matty thnx for the contact info for the dealer and the part info i was looking for it too.
There's an auto parts store on Ebay that is selling the entire radiator support piece (new)for $52 plus $60 shipping. Looks like a lot of work to do the entire thing...
