Interior Door Light Wont Work.
Old Nov 19, 2006 | 01:26 PM
maxman92's Avatar
I was changing the bulbs in the doors and I touched both sides of the bulb with a screwdriver and now the pass side door light wont come on. I had this problem before when I first got the car and it had something to do with the window switch. I changed the switch and the light worked again.
Do I have to change the switch again or is there a way to fix this? I dont understand why the light would run through the window switch but it does.
Any help would be great!
Old Nov 19, 2006 | 01:50 PM
Cdg2125's Avatar
Did you check the bulb? It shouldnt have anything to do with the switch. Maybe lose wires, or the bulb is just dead.
Old Nov 19, 2006 | 02:15 PM
maxman92's Avatar
Its not the bulb or lose wires. I have done this before by touching the 2 wires together and the only way i could get the same bulb to turn on was to change the switch.
Did anyone else have this problem?
Old Nov 19, 2006 | 03:25 PM
95GLEMAXX's Avatar
window switch might be bad
Old Nov 19, 2006 | 03:57 PM
kcryan's Avatar
fuse??????????????
Old Nov 19, 2006 | 06:02 PM
venompwr2's Avatar
I did the exact same thing with a screwdriver, and the light doesnt turn off now. I just left it unplugged and never bothered to fix it.
Old Nov 19, 2006 | 08:37 PM
kbmaxima's Avatar
there is a fuse inherent to the master driver's side window switch. That has gone byebye. easy fix: get a new driver's master window switch and swap.
Old Nov 20, 2006 | 08:14 AM
BORQUA79's Avatar
nycmaximas member
Intresting.... Ive had my passenger light out for a while i should try this... But then again getting a whole drivers side switch... Is that the part with the windows, door lock buttons on the arm rest??? If soo Getting a replacement for the light isnt worth the money??? well for me that is...
Old Nov 20, 2006 | 02:25 PM
maxman92's Avatar
If it is the pass side door light that is out and the drivers side works then the pass side switch needs to be replaced not the drivers side. I just replaced my pass side switch and the light works.
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
vrajesh123
Aug 31, 2015 11:00 AM
rbaker100
Aug 28, 2015 08:11 PM
