What Tool To Use to Loosen Nut on Idler Pulley?
I'm trying to loosen the nut on the idler pulley so that I can tighten the belt using that adjustment **** above. I'm having a tough time getting the nut loose since it's such a tight spot right there. Any tips on what tools would be best to use to get the job done?
Thanks guys...it looks like the nut is kinda damaged. I need one of those wrenches that make contact with the flat sides of the nut and not the edges. If and when I get that nut loosened, I can just replace the nut with a new 14mm nut right?
clockwise is tighten, counterclockwise is loosen for the pulley, but it's REVERSED with the top adjustment ****. Clockwise will loosen the belt, so make sure you go counterclockwise to tighten it. (it's a lefthand thread) You'll figure it out. Also, hit that top **** with some WD40 or equivalent, mine seized up and broke in half. My car was stuck in the driveway for 3 days until I had the chance to make a knew one. Good luck.
Originally Posted by GCOBBLE
If I remember correctly, I found it easier to get to the bolt fromm the bottom of the car.
BlackCat, was your idler pulley nut stripped as well?
knight_yyz
Nov 1, 2015 01:34 PM
