p0136 0707 - Dreaded rear o2 sensor code, need help...
Old Nov 21, 2006 | 03:16 PM
soybeanz's Avatar
I scanned for the code and got p0136, so I ordered a brand new rear o2 sensor from the dealer. Got it installed and made sure everything was connected tight. Cleared the code and took a short drive (about 5 minutes) and the p0136 code came back.
P0136 - Downstream oxygen sensor or circuit fault
What else could be the problem if its not the o2 sensor ?
Old Nov 21, 2006 | 03:19 PM
1FSTMAX's Avatar
get an o2 sim... are you sure you changed the downstream o2?
Old Nov 21, 2006 | 04:34 PM
soybeanz's Avatar
I definitely changed the sensor after the cat, and not the ones on the y-pipe.
I wouldn't want to try an o2 simulator unless that was the last resort. I thought 02 simulators were used if you had no cats ( a different trouble code) , or if you wanted to get rid of the o2 sensor altogether.
The rear sensor is brand new from the dealer, so I'm just hoping it isn't some other electrical problem.
Does anyone know what could cause P0136 (0707) - Downstream oxygen sensor or circuit fault besides the actual o2 sensor?
Old Nov 21, 2006 | 04:40 PM
chillin014's Avatar
i've replaced mine too and the code comes back.
what is a circuit fault? like an accidental throwing of the code?
Old Nov 21, 2006 | 04:52 PM
matrix11229's Avatar
Did you get the correct O2 sensor with 4 wires ?
Try to reset it again , if the code comes back go back to the dealership and return it for a refund or exchange it for another one.
Better get a refund and get the Bosch sensor from ebay for $28 shipped. You will save a lot of money (let me know if you need a link). I bought my rear O2 sensor on ebay and it works perfect. Even the Evap codes disappeared after I installed the new O2.
There might be also a physical damage to the cat converter, may be that's why the sensor isn't getting any readings.
Old Nov 21, 2006 | 05:36 PM
soybeanz's Avatar
I have the old sensor in my hands and I only see 3 wires (red,black,white).
$28 shipped? Is it a universal sensor that you need to splice? sure PM me the link...
Are you sure you had 4 wires?
Old Nov 21, 2006 | 06:01 PM
Are you sure you removed the correct sensor ? Only the front sensors have 3 wires. The back sensor has 4 wires.
You have to remove the sensor which is inside the cat converter (under the front seats), not the ones in the engine bay.
Here are the links:
The bosch listing just ended so you will have to wait for it to be relisted or just contact the seller: http://cgi.ebay.com/ebaymotors/NEW-B...temZ8057792500
Here is the NGK which is good too: http://cgi.ebay.com/ebaymotors/NEW-N...mZ160043758959
This is the link for all maxima sensors from this seller:
http://search.stores.ebay.com/GLOBAL...271212QQsofpZ0
Old Nov 21, 2006 | 06:09 PM
Yes I'm positive , it has 4 wires (0707= rear O2 sensor).
I installed all 3 O2 sensors together with my mechanic (I spliced the wires by myself). Only the front sensors have 3 wires; the rear one has 4 wires.
Who installed your sensor ? Probably they took out the front sensor instead of the rear one. Those mechanics know less than average .org member
Old Nov 21, 2006 | 06:24 PM
CRiME's Avatar
oem ftw!
what year is the car? if he has a 1995, the sensor only has 3 wires. If you changed the sensor and the code returned, you might have a problem with your cat, or y pipe. I'd check those things out.
Old Nov 21, 2006 | 06:33 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
what a coincidence .... I"m having the same code ... although I haven't replaced it yet ... but mine comes and goes ....
Old Nov 21, 2006 | 07:51 PM
soybeanz's Avatar
I did have my mechanic replace it, but I was standing under the car the entire time watching him. Its definitely the o2 sensor on the cat, under the seats.
The year is a 96, manufactured 3/96. I'll probably take a closer look myself when I have time on Thursday, at the very least to verify all the wiring.
I do have a high flow cat, but thats been there for 2-3 years now, but I assume that could be part of the problem. Wouldn't a bad cat throw in a different DTC?
Old Nov 23, 2006 | 08:26 AM
soybeanz's Avatar
gobble gobble
Went under the car and made sure the sensor was on tight and then I checked the connector/harness and everything looks good. I reset the code and drove 15 minutes and the code came back. Reset it again, 15 minutes later its back again.
dayam... I need to pass inspection this month. Any other ideas?
Old Feb 11, 2007 | 04:05 PM
Xtr3m3X's Avatar
Reppin' the 216
So hey soybeanz, what happened? I have the same problem as you now, and I'm trying to figure out what I have to do.
Would a Bosch sensor provide the same quality as an OEM one? For example the one matrix11229 gave you the link for ->
Anyone!!! Please help!
Old Feb 11, 2007 | 09:56 PM
Toolrocks's Avatar
Yeah, what happened. I would suggest checking fuses first, then clean the 2 grounds located right in front of the intake manifold. If that doesn't work I'd then check for voltage at the O2 sensor, and if that all fails, I'd check for coninuity of all the harnesses. Good luck.
Old Feb 16, 2007 | 07:42 AM
Deep's Avatar
soybeanz,
How did things turn out? I've got the same code and the mechanic says it's going to be $200+. I was wondering if I should attempt this myself? But I wanted to get your input and see what you thought.
So, do let me know. I'd send you a PM but I don't have enough privelages yet.
Thanks,
-deep
Old Feb 16, 2007 | 08:08 AM
sky jumper
for those with recurring O2 code -- it could just be a defective sensor. or the mechanic got anti-seize on the sensor head, etc etc. either way, have the mechanic fix his work.
Old Feb 19, 2007 | 12:30 PM
Deep's Avatar
Got it sky jumper. About to give DaveB a call for a new O2 sensor! Let's see how this goes.
kjlouis
Nov 24, 2018 06:09 AM
Huttig2009
Sep 25, 2015 03:31 PM
lux97Max
19
Aug 27, 2015 07:48 PM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
