Flashing Dash
Old Nov 22, 2006 | 10:52 PM
DragonMaxima's Avatar
Flashing Dash
Noticed briefly that my Battery and E-Brake dash lights were blinking simultaneously.
Does this mean my battery is going to die soon?
Old Nov 22, 2006 | 10:57 PM
andrei3333's Avatar
probly, but e brake ? no clue, read the stickies dude
Old Nov 23, 2006 | 01:14 AM
LiGhtSoUt's Avatar
i had a similar problem i was driving i stoped the car then my dash lights started flashing the battery and one other one and the car just came to a stop started up happed agan started up again so im guessing its the battery going
Old Nov 23, 2006 | 07:24 AM
CRiME's Avatar
oem ftw!
flashing brake and battery lights usually indicate a failing alternator. have the battery checked first, if it's good, then have the alternator checked. i think you can have both things done at autozone
Old Nov 23, 2006 | 08:33 AM
99grnmaxgxe's Avatar
on the alternator.
Old Nov 23, 2006 | 09:23 AM
Thanks everybody. I just recently changed my alternator. So I'm guessing its the battery. How often do we need to change the battery? I think I changed it 2 years ago.
Old Nov 23, 2006 | 09:39 AM
2da mizzax's Avatar
take it in to autozone and get it tested. or, leave your lights on for 30 min. if the car doesnt start up your batt is toast (thats the cheap way to test it). i have never heard of a battery setting off the light before on a max though.
http://www.2carpros.com/topics/warning.htm
according to this link and some other i found it seems to be an alternator problem. perhaps you should get it exchanged?
Old Nov 23, 2006 | 07:05 PM
LiGhtSoUt's Avatar
is the car still driveable if the alternator is weak and lights have flashed ?? checked the battery and it wasnt it so im guessing its the alternator
Old Nov 23, 2006 | 07:34 PM
Luisjo's Avatar
If the alternator is failing the car light should turn dim when you put the car stereo on high volume (it happened to me) if it happens to you it may be it. So to get it checked just start the car open the hood and remove the negative (black) ring (or something) from the battery if it shuts down then its the alternator if it doesent then its.... something else i dont know. Just my .02
Old Nov 23, 2006 | 07:42 PM
pmohr's Avatar
No more Maximas...
Driveable, yes. Driveable far? Not if your alternator won't charge your battery.
Old Nov 23, 2006 | 08:26 PM
massfastmax's Avatar
its the alt it happened to me last summer and just happened to one of my friends your bat might be low but thats probably because the alt isn't charging it
LiGhtSoUt's Avatar
i tried that i out i started the car left it running disconnected the negative terminal nothing happened after i disconnected thee positive then it shut offf i guess i might have to loook for some codes
Old Nov 23, 2006 | 08:44 PM
Luisjo's Avatar
i dont know if the positive has anything to do with it since you can disconect both to change the battery, so you know theres something wrong, But last week it happened to me that i left the red one disconected and in the middle of the street the car turned of when i checked the positive was disconeted. So it might be it, but my batterie went dead sometime ago and i started the car disconected both and changed the battery and nothing happened so you must check that out
P.S. turn on the car then check the voltage on the battery to se if it passes 12.5 if not then its the alternator also
Old Nov 23, 2006 | 09:01 PM
LiGhtSoUt's Avatar
soo run it and disconnect only the positive is wat ur sying?? im just trying to do some self tests before i take it to autozone
Old Nov 23, 2006 | 09:15 PM
Luisjo's Avatar
Well. the car SHOULDNT turn off even if is the positive alone. it shouldnt happen. if you have a voltmeter try to check the voltage. im positive its the alternator
Old Nov 23, 2006 | 09:33 PM
From the link that was posted the guy was driving and the lights flashed.
For me the lights only flash when I'm parked and have the key on ACC I believe. This is where my radio works and I can roll down my windows.
Old Nov 23, 2006 | 09:38 PM
LiGhtSoUt's Avatar
mine was the total opposite i was just driving went to make a right turn and then the car just lost power on me and the oil and battery light flashed then i just pulled the car over then the car stalled i waited 1 min restarted it and then the same thing happened at the next light and then i jsut parked it for good
Old Nov 23, 2006 | 11:04 PM
2da mizzax's Avatar
http://forums.maxima.org/showthread.php?t=478690
Old Nov 23, 2006 | 11:22 PM
Thanks for the Link but I've just changed the Alternator.
Also when my car is fully turned on the lights don't appear. The only time I've seen them flash was when the car was off in the ACC position. Not sure if that means anything.
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
dshinn
Sep 26, 2015 08:07 PM
