Clutch Problem.. please help
Old Nov 26, 2006 | 10:10 AM
kismias7's Avatar
I just got a new clutch put on about a week ago. I noticed it was smelling a lot and also slipping so i took it to my mechanic. He said it was the slave cylinder and replaced it. The clutch does not slip anymore but it is still smelling alot. Also when i was stopped at a red light i noticed some smoke coming out from under my hood. WHAT COULD THIS BE????
Old Nov 26, 2006 | 10:30 AM
Pieps's Avatar
The mechanic could have spilled brake fluid on the transmission while bleeding the slave cylinder causing it to smoke...just a thought, i am not saying that is the cause
Old Nov 26, 2006 | 03:04 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
you think that mine may be slipping cause of the slave cylinder ? my clutch is frekin brand new and it slips. my slave cylinder is from a 95 parts car. how can i tell if its gone bad ?
Old Nov 26, 2006 | 04:08 PM
djengr's Avatar
I would not think a bad slave cylinder would cause the clutch to slip, unless you are leaking brake fluid so bad it is getting onto the clutch plate. If that was the case it will take a while to burn all the fluid off.
Did you notice the clutch fluid resevoir needing fluid. If you have not had to fill the clutch fluid resevoir then I think there is something else going on.
Good luck.
Old Nov 26, 2006 | 04:48 PM
NotoriousMAX's Avatar
check your engine oil...it could be that your main seal is leaking oil into the transmission and that is why the clutch slips and you see smoke...
Old Nov 27, 2006 | 06:57 AM
kismias7's Avatar
does anyone know why I am smellin my clutch so much?
Old Nov 28, 2006 | 03:26 PM
Greener's Avatar
I just had a new clutch put in because my chutch was chattering. Brough it back to the mechanic because it was still chattering. He put in ANOTHER new clutch and a new flywheel. It's still chattering.
Wonder if our problems are related...
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
Maxxx10
Sep 13, 2015 03:16 PM
