Hunting for negative battery cable bolted to block/chassis
Old Nov 29, 2006 | 01:20 PM
charlestek's Avatar
As part of trying to diagnose my cold starting problem in my '96 GLE, I want to check the
connection of my negative battery cable to the block. It looks like it is buried under the air filter/throttle body assembly. Anyone know quickly what you have to take off to get at it?
Also I tend to believe that I really have a rest pressure fuel problem, so has anyone had problems with the fuel pressure regulator or the check valve in the fuel pump in this regard at high miles (120k)
Thanks,
Phil
Old Nov 29, 2006 | 02:49 PM
Maxima880's Avatar
It's bolted to the front bank exhaust manifold driver's side directly below where the upper radiator hose enters the block.
Old Nov 29, 2006 | 03:02 PM
f550maranello2's Avatar
just get a new one.. wallmart ftw $10
Old Nov 29, 2006 | 03:07 PM
charlestek's Avatar
Will Check
I would replace it if it is bad. I didn't say I found any corrosion or deterioration. I have to look at the place where it bolts to the manifold.
I seriously doubt it is bad anyway. If something is wrong it is more likely it is at the contact point than the cable itself.
This looks like a rest pressure fuel starvation problem or some other cold fuel enrichment problem.
Old Nov 29, 2006 | 03:53 PM
99se5speed's Avatar
SHIFT_up
so how about your try and listen to see if the pump turns on when you turn the key to the "on" posistion to check...?
Old Nov 29, 2006 | 03:55 PM
charlestek's Avatar
?Pump must turn on
The car has trouble starting when it gets cold. The pump would have to work, otherwise it would never run...
gigabyte
Jan 6, 2017 06:05 PM
BobTX10
Oct 7, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
bigfrank
Oct 1, 2015 12:51 PM
