O2 sensor signal wire from ECU
Old Nov 29, 2006 | 05:55 PM
NAS's Avatar
NAS
wondering if anyone knows which wire comming out of the ECU is the signal wire for the O2 sensors? I am going to install a AFR gauge and need to tap this wire. thanks
Old Nov 29, 2006 | 06:22 PM
acidspit86's Avatar
im pretty sure you dont want to tap in there. go in at the wires directly by the o2 sensor, by the exhaust. there are 3 wires, red, black, and white. i think. i also think that the white on is the ecu wire, but dont quote me on it, im not 100% sure.
edit: on second thought if your hooking up a guage, then maybe its not a good idea to run the wire all along the bottom of the car, unless it is going to the left or right bank o2 sensors
Old Nov 29, 2006 | 08:03 PM
pmohr's Avatar
No more Maximas...
Narrowband A/F gauge is just shy of absolutely worthless.
Old Nov 29, 2006 | 08:13 PM
95turbo gxe's Avatar
its a waste of time to install. Are you trying to tune the car. what Mods do you have? Do you know how fast a narrow band gauge move. You would be better off tunning with one of these!
Old Nov 29, 2006 | 09:06 PM
nismology's Avatar
The stock narrow-band signal is worthless.
Light show time!!
Old Nov 29, 2006 | 10:20 PM
NAS's Avatar
NAS
well since I dyno'd the car after the NX install it showed that im running rich at wot all the time and even worse with the n2o of course being a wet kit. I ended up going with a the smallest fuel jet that came with the kit since according to the dyno info it runs 11.3-11.8 afr all the time anyway. I was going to get the small square digital gauge from dynotunenitrous to just keep an eye on it and then I hoped to get an SAFCII and mess around.. im not sure what else to do, the car only runs rich at wot, runs great, spectacular gas mileage, what I think is alot of carbon or unburnt fuel(black s*%t) in my exhaust tip. im kinda stumped
Old Nov 29, 2006 | 10:49 PM
NmexMAX's Avatar
dot dot dot ...
There's a definite pattern recognized in this thread.
WB > NB
Couple your SAFCII with a wideband 02 sensor that tapped/bunged/taking radings before the cat. (test pipe maybe)
If I may suggest a wb, try the PLX R300. Affordable, and able to take readings of 5 different sensors. And you do not need to 'purchase' a separate RPM converter (i.e Innovative)
bbsitum
Sep 6, 2019 07:31 PM
mix master
Sep 4, 2015 05:50 PM
