help maxima is sputtering
Old Dec 5, 2006 | 01:09 AM
96nismomaxi's Avatar
.org window licker
my car (maxima) keeps sputtering for some reason and the only thing that i can think it could be is the IACV, the TB positioning sensor, or the spark to the motor if anyone could think of anything else please help
a little info the car has 140k miles on it, it is a 5 speed, and the problem is only noticed when i am at idle....which kinda rules out the spark for me in my mind please tell me if im wrong
Old Dec 5, 2006 | 08:39 AM
babymac's Avatar
BOOST 4 LIFE!
Sounds like you might have a vacuum leak??
Old Dec 6, 2006 | 01:52 PM
.org window licker
ill check thx
Old Dec 6, 2006 | 04:44 PM
dallas0593's Avatar
Could be a number of things. Start with the easiest and cheapest and work your way up.
1. Clean throttlebody.
2. Clean IACV
3. Replace Air filter
4. Fuel Fuel Filter
5. Replace spark plugs.
then you start getting into more complex and exspensive items like o2 sensors,fuel injectors, coil packs etc etc. Start with the 1st 5 and see what happens then go from there.
Old Dec 11, 2006 | 08:16 PM
dshadow35's Avatar
Good luck, i finally got mine figured out. Damn Coilpacks.
Old Dec 11, 2006 | 10:11 PM
gen4maxima536's Avatar
you've got a 99 with all those coil problems, so that would be way up there on my list of things to check
Old Dec 12, 2006 | 08:39 AM
heynow's Avatar
no sparky, bad coil/s?
Old Dec 12, 2006 | 08:56 AM
MaximaSE96's Avatar
Maxima Owner
sounds like coil packs to me....idle sucks.....then probably goes away past 3k....yea i would bet on coils...especially being a 99
Old Dec 12, 2006 | 09:05 AM
Dexter's Avatar
don't bad coils throw a misfire code?
it will also sputter @ idle if it has a clogged EGR pipe (like mine did) but then again it should throw 0302 if that's the case
Old Dec 12, 2006 | 09:09 AM
MaximaSE96's Avatar
Maxima Owner
mine didnt on my 96
Old Dec 12, 2006 | 09:10 AM
2da mizzax's Avatar
2. Clean IACV
4. Fuel Fuel Filter
Do the simple cheap stuff first. Rule those out. Then get into coils etc if tht is your problem. You prob need to do everything on his list anyhow.
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
