Car smells like Gas
Old Dec 5, 2006 | 11:44 AM
Obespalov's Avatar
Car smells like Gas
Hi, since the cold weather started, I'm getting some smell of gasoline coming through the vents (I think). I have a 96 I30 w/ 183,000 miles on it. A google search says it could be a bunch of stuff. Does anyone know what is the most probable cause of the smell so I can start there first. If on the fuel line, where should I look and what should I look for?
Old Dec 5, 2006 | 12:04 PM
99se5speed's Avatar
SHIFT_up
It could be your Catalytic Converter.
Old Dec 5, 2006 | 12:31 PM
Obespalov's Avatar
I meant 'gas' as in gasoline, not as in farts or rotten eggs
Old Dec 5, 2006 | 12:42 PM
2da mizzax's Avatar
glad you said it and not me. anyhow, check for moisture around fuel lines and connectors under the hood. if you can jack up the car, look at fuel lines for rust. there is no reason for the smell to be coming from the vents unless there is a leak under the hood. if it is under the car, you will still smell it in the car and perhaps the heat will make it seem stronger. another thing to check is the seal for your fuel pump cover under your rear bench.
Old Dec 5, 2006 | 12:56 PM
Obespalov's Avatar
cold weather + looking for some obscure leak= bad times.
Old Dec 5, 2006 | 01:20 PM
mad greek's Avatar
The fuel supply and return lines to the injectors on the engine or the most likely cause.Sometimes the clamps can be tighten but thats a temp. fix only. The hoses and clamps should be replaced w/FACTORY hose and band clamps,not aftermarket,for proper fit.Use caution when removing lines,cool engine, relive fuel pressure,no smoking.Id suggest not holding off to long,under hood fires are a ***** to repair.
Old Dec 5, 2006 | 01:51 PM
Obespalov's Avatar
Easy repair? Or should I just pay shop to take care of it? If so, how much does it cost?
Old Dec 5, 2006 | 09:34 PM
Digitized's Avatar
does the smell go away or it stays in the car even when driving?
if it's only on startup, could perhaps also be leaky injector or 1 plug not firing?
Old Dec 6, 2006 | 06:51 AM
Obespalov's Avatar
Well, I smelled today the car under the hood and it seems the smell is coming from there. Does that narrow down where the source is?
Old Dec 6, 2006 | 07:24 AM
Digitized's Avatar
Check your spark plugs
Check your fuel pressure
like others said also, check your fuel line connnectors..
Old Dec 6, 2006 | 08:38 AM
Obespalov's Avatar
Is there a diagram available of where all the fuel lines are. I'm looking at the engine and I can't figure out what line goes where with what. I also have the Haynes manual for reference if anyone has a page number to look at.
Old Dec 6, 2006 | 11:54 AM
clive's Avatar
100% chingon
Gah. . . nobody mentioned the obvious.
If the smell only occurs once in a while, and usually when you switch off, it is probably the . . . ermm. . . can't recall the technical name, the EGR valve is it? Anyway the purge valve that's connected to a charcoal can that regulates gas tank purging. It's a fairly common problem on 10 yr old cars.
Old Dec 6, 2006 | 12:01 PM
2da mizzax's Avatar
if it is the EGR valve, or bad plugs etc or anything that is internal and he smells it then he has more than one big problem as it is a closed system and should not be smelling. more likely than not it is one of the hoses that is a part of the fuel feed.
Lakersallday24
Jun 16, 2019 01:35 AM
PH98I30
19
Jun 13, 2016 02:38 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
Balkins
Aug 12, 2015 06:39 AM
