Clutch makes loud click when pushed in
Old Dec 5, 2006 | 03:10 PM
scrhale's Avatar
OH CRAP! Just started happening when I got back from the big bad dining hall. This occurs even when the car is off. Everytime I push the clutch in, it makes this loud TICK when it is just passed 3/4's in. I was trying to figure out where the sound is coming from and it seems like it is coming from this black rubber spring looking thing that moves back and forth from the transmission as you push it down. I searched but did not find anything in the forum nor the FAQ.
I will make a video if someone can not figure it out.
EDIT: VIDEO POSTED. The visibility is poor, but the purpose is the sound and you can kinda see the location. PLEASE HELP with identification of the problem.
Video Here
Old Dec 5, 2006 | 03:30 PM
dgeesaman's Avatar
Maintenance Monster
That black rubber thing is probably the cover for the throwout arm. The retaining spring for the arm or the throwout bearing itself may have broken.
Dave
Old Dec 5, 2006 | 03:34 PM
Apparition's Avatar
Ichiban King
Dave
Mine squeaks and my new clutch was put it in february.. Dunno what the problem is there either.
Old Dec 5, 2006 | 03:37 PM
willard00's Avatar
sounds like the throwout bearing's busted
Old Dec 5, 2006 | 03:38 PM
willard00's Avatar
doublepost, sorry
Old Dec 5, 2006 | 05:06 PM
dgeesaman's Avatar
Maintenance Monster
Squeaking and a loud tick sound are two different things in my opinion.
Dave
Old Dec 5, 2006 | 06:17 PM
Apparition's Avatar
Ichiban King
Dave
I just wanted SuperDave's opinion haha.
Old Dec 5, 2006 | 08:02 PM
scrhale's Avatar
Oh it is no squeak. A way to kinda simulate the sound is just take the hood latch, pull it then let go. It is not that loud, but nearly. It is almost like a weak knock coming from the transmission. UGH this has me scared ****less. My 95 is in Alpharetta and I am stuck in Athens/UGA!!!
Old Dec 6, 2006 | 01:58 PM
MireLanski's Avatar
Mine ticked. It was the $5 dollar bushing that actually goes on the part of the assembly where the master cylinder meets the pedal. Inside the cabin.
Look there...should only take you a few minutes to find the culprit.
Old Dec 6, 2006 | 04:53 PM
scrhale's Avatar
OMG thanks a million. The only small problem is that I cannot work on the car in Athens. Do you think the car will make it an hour and 15 minutes home. I may end up hitting traffic
Old Dec 6, 2006 | 05:03 PM
scrhale's Avatar
DAMN! Just went out to check it out. The sound is DEFINETLY not coming from in the cabin. I will try to take a video of it tomorrow. I took the car around the block and clutch was still working despite the noise ... thank god.
Old Dec 7, 2006 | 11:52 AM
MireLanski's Avatar
check master cylinder...Have some one depress the clutch while you are under the hood. Can only be one of three....pedal, slave cylinder or master. You don't think it's actually the clutch itself. The spring like pitch fork may be on its way loose around the **** causing it click back every time the clutch is disengaged.
Old Dec 8, 2006 | 02:58 PM
scrhale's Avatar
Bumping for video posted in post #1.
Old Dec 9, 2006 | 09:18 AM
scrhale's Avatar
Bump again I really need this done cause I want to drive my 5Spd and not my 95 GLE boat.
Video Here
BkGreen97
Apr 2, 2016 05:47 AM
220k+ A32
Sep 11, 2015 02:18 AM
maxfever1987
Sep 6, 2015 06:20 PM
