Transmission Problem....(uggghhh)
Old Dec 6, 2006 | 09:26 AM
Racer_M's Avatar
You know how I do....
So I drove my car this morning. Started it up, drove for about 10 mins, come to a stop sign and *BANG* the car no longer drives. Initially I thought I hit a pothole, but i was at a complete stop, then I thought I nudged it into neutral...I shifted to 1, 2, back to d, then i finally put it in park and the car continued to roll because I was on a slight slope. I had no prior issues with anything on the car except the control arms and tie rods. I'm towing it to a shop later today or tomorrow, they'll get to the root of the problem...hopefully, and hopefully it won't dent my wallet because I honestly don't have the money to get it fixed.
Things to know, it's an 98 se autocrapic, 107k miles, has a vq30de-k(35k), and it was cold as hell this morning, other than that the car ran perfectly for the 9 months i've had it. No problems shifting, no abnormal noises, I drove the car damn near everyday...sometimes for hours on end and nothing even remotely seemed wrong with it.
P.S. I tried to use the search but I kept getting some error about too many characters or some shyt to that effect...
Old Dec 6, 2006 | 09:42 AM
moogotzskillz2's Avatar
Damn bro, that sucks... hope it aint that much/bad to fix..
but, DId u check if u had tranny fluid? or did u warm up the car..(since it was very cold outside)
i was told that tranny fluid over night drains out of the torque converter so u should warm it up... then it should run fine..
Old Dec 6, 2006 | 10:28 AM
sky jumper
did you ever check the fluid level/condition? the cold temp could be a coincidence, but burnt/dirty fluid could thicken beyond limits when cold triggering the failure.
trannys are very complex. keep us posted as to what they find, and do an ATF drain/fill every 15k from now on (it's cheap, easy, and effective).
Old Dec 6, 2006 | 12:00 PM
Racer_M's Avatar
checked the fluid, maybe a month or so ago, it was good. I'll check it when I go back to my car later today...I don't check it as often as oil level, will do that from now on...but apparantly its too late anyway. I didn't have any leaks and the level was fine. I didn't let it warm up much when I got into the car today, was in a rush...
Old Dec 6, 2006 | 12:03 PM
mbandi's Avatar
Da'Burgh, Go Stillers!
So let me get this straight, it rolls even in park? Are you sure your cv shaft didn't come out or break at the joint?
Old Dec 6, 2006 | 11:26 PM
Racer_M's Avatar
I beginning to think it might be the axles. I didn't do a thorough examination, but from what I can recall that might be the culprit. My car got impounded so im going to check when i get it out today.
Old Dec 7, 2006 | 11:04 AM
sky jumper
impounded? what happened??
Edit: oh no - you didn't leave it stranded on the street did you??
Old Dec 7, 2006 | 12:10 PM
Racer_M's Avatar
I pushed it into a parking lot for an apartment complex...they must have been watching me because they towed it 30 mins after i left it. Well everyone i talked to seems to think its the axles now...even the transmission place said they believe its that. Theres a grinding noise when i shift and it doesn't stay still and the speedometer moves when i hit the gas...
my car is lowered 1 1/2 inches...could these pothole covered philly streets be causing this? i already had to get new control arms and a front end alignment...
Old Dec 7, 2006 | 12:40 PM
willard00's Avatar
could be the potholes. usually they dont mix with lowered cars. although 1 1/2 isnt too bad. how long ago did you replace the axles? may be a warrenty still. and when my tranny died there was no noise at all, it just wouldnt shift out of first, so i floored it and could only go 25MHP! damn i was flyyinngggg. so it very well could probably have been axles.
Old Dec 11, 2006 | 08:14 PM
dshadow35's Avatar
Ouch potholes.
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
