Car dying after start up...NEED HELP
Old Dec 6, 2006 | 01:34 PM
Max_N_Action's Avatar
hey my girlfriend's 95 maxima has a problem. When i start the car, it starts and then the idle drops and the car dies. If i rev the engine a lil and keep the idle going for a few seconds, then its ok. It happens all the time. Any idea why it could be doing this?
Old Dec 6, 2006 | 01:53 PM
shissqbob's Avatar
same problem just started for me yesterday man....ahh it sucks
Old Dec 6, 2006 | 03:29 PM
pei's Avatar
pei
check ur MAFS & TPS.
Old Dec 6, 2006 | 03:56 PM
Geophrum's Avatar
clean the TB.. tis the season for this to happen alot more... The gunk on and around the butterfly in the TB hardens during the colder weather. causing you to have to brake past the sludge.. even if it is a small amount.
try this before you start worrying about expensive repairs
http://www.motorvate.ca/mvp.php/517
Old Dec 7, 2006 | 11:55 AM
MireLanski's Avatar
does it sound like it's running out of fuel. Could be fuel pump. Or Fuel relay fuse. Check that.
Old Dec 7, 2006 | 12:04 PM
jattdemax's Avatar
I feel you i have the same problem
Old Dec 7, 2006 | 12:23 PM
CRiME's Avatar
oem ftw!
Sounds like it might be the Engine Coolant Temp Sensor. Changing this has fixed that exact problem for many people.
Old Dec 7, 2006 | 12:51 PM
2da mizzax's Avatar
clean it first before you go buying parts. and a bad coolant temp sensor will work in reverse. acting up when the car is warm because the ECU still thinks it is cold.
Old Dec 7, 2006 | 03:18 PM
CRiME's Avatar
oem ftw!
oh didn't know that, i thought it could cause stalling when cold or warm. but anyway you can check your codes too if you haven't already. the faulty ECTS will give you code 0908. if that's your problem, and cleaning doesn't work, it's only around $20-$30.
Old Dec 7, 2006 | 04:46 PM
BK1's Avatar
BK1
Hello
I had the same problem last year, it was a dirty throttle body. Changed the coolant temp sensor, and MAF (those weren't the problem on mine) before I cleaned the TB. Do that first since its the cheapest
Old Dec 7, 2006 | 07:30 PM
shadyonedeath's Avatar
My car stalled on me tonight on the freeway in stop'N'Go Traffic.
Cars started to move and all of a sudden my gas pedal didnt rev the engine and all the gauge cluster lights turned on. I started it again, and it happened a second time. I had to keep putting it in neutral and rev'in it in order to stay moving.
Any idea? Its been working fine before..
Old Dec 7, 2006 | 08:17 PM
matty's Avatar
It cant be just a dirty TB...I have this problem too..I think its the IACV
-matt
Old Dec 7, 2006 | 09:01 PM
AxisKill's Avatar
it could be your car just being moody in the cold weather or it could be a serious problem..
definitly do the TB cleaning as shown on the motorvate site ^
i had the same problem (before it got cold outside) and so i changed my oil and spark plugs.. and no more problem.
also definitly check for CEL codes as mentioned above.. if a combo of TB cleaning, oil change and spark plug change dont do it.. then you may have a problem.
Old Dec 7, 2006 | 09:03 PM
My TB/IACV/IM are spotless. Cleaned them about 2 months ago.
Old Dec 7, 2006 | 09:10 PM
'96 B-rad's Avatar
I have the same problem think its a wire to my iacv thats messed up
Old Dec 8, 2006 | 01:02 AM
nick's Avatar
Guys, check your MAF sensor ground
http://forums.maxima.org/showthread.php?t=502009
Old Dec 8, 2006 | 03:51 AM
2da mizzax's Avatar
totally different problem from the original poster. He has a cold die and you have a hot stall. now yours sounds like it may be the coolant temp sensor (or even may need a coolant system flush if there is any buildup). You have a few more possible causes.
Old Dec 8, 2006 | 08:54 AM
jremignanti's Avatar
Is the check engine light on? If yes, did you check the codes? Knowing that the light is/isn't on may eliminate a few possibilities.
Old Dec 8, 2006 | 11:12 AM
thanks,
Where is the coolant temp sensor? I did notice my needle acting a bit funny.
Old Dec 8, 2006 | 11:17 AM
matty's Avatar
thanks,
Its on the Right side of the motor on the coolant log. There are Two sensor there...One (smaller one) is for your temp gauge, and the larger one with the larger connector is your ECTS
-matt
Old Dec 8, 2006 | 12:54 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
... I had the same issue ... and changing the ECTS helped me ... good luck
Ali
Old Dec 8, 2006 | 01:03 PM
matty's Avatar
Ali
z
Yours was hunting and stalling at cold start or all the time ??
-matt
Old Dec 8, 2006 | 03:15 PM
Maverick7687's Avatar
Mine just started this today. I have one more symptom though. When starting, I can hold they key in the "Start" position and the motor will spin over a couple times, then act like I turned the key back, then right back over.. Kind of a delay in the starter or something, only for a split-second. I am thinking that may be my starter but it still doesn't explain the other problem. Unless the starter getting stuck can pull the motor down after start-up as well.
Old Dec 8, 2006 | 03:17 PM
'96 B-rad's Avatar
Could the ects cause stalling when switching to reverse? Because I thought it was my iacv that was causing that problem so I got a new one put in but I still have the same problem. Although its much less which is why I think it may be a wire to the iacv or something. And now I have the same problem as max n action
Old Dec 8, 2006 | 03:46 PM
2da mizzax's Avatar
maveric, check your battery and super-ground your starter.
brad, check yoru radiator for coolant (to make sure it is full). air pockets can cause that when warm. but the temp sensor may be the cause.
Old Dec 8, 2006 | 10:15 PM
yea actually the engine light came on aroudn the same time as this problem.... does that narrow down the possibilities?
Old Dec 9, 2006 | 01:02 AM
-matt
Thanks bro.
Is it just a plug? I disconnected the bigger plug and it was full of all this orange/brown grease. I cleaned it out thinking it caused a faulty connection.
I couldn't find where the plug lead to. Anymore tips?
Old Dec 9, 2006 | 10:39 AM
Definitely.
Did you check the codes yet? Do you know how to do it? Look in the stickies on the main page if you don't. There's a "help, my check engine light it on" thread.
If it's a sensor problem, the code that you get should tell you what the issue is. If it is the coolant temp sensor the code will br 01 03 or 09 08.
let me know what you come up with.
Old Dec 17, 2006 | 12:31 AM
Bump to this question. Mine also stalls when shifting gears.
anyways, can someone provide pics of the ECTS and how to change it/buy replacement/install it/anything else?
ps: i've noticed my Temp gauge acting funny at times, sometimes on the highway it will be at mid range, and then drop half way really quickly.
Old Dec 17, 2006 | 04:53 AM
nhaven's Avatar
19mm wrench and some teflon tape, got my ects from advance auto for ~$27
Old Dec 17, 2006 | 05:58 AM
maxspeed96CT's Avatar
The original VQ...
Im having the same problem but my car dies and doesn't run, changed the coolant sensor so far, and got nothing.
I looked for a fuel pump relay and did not see one? What is it labled as??
Here my thread
http://forums.maxima.org/showthread.php?t=503480
Old Dec 17, 2006 | 02:04 PM
thanks nHaven.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
