Removing the rear bumper cover
Old Dec 16, 2006 | 11:13 AM
krillbee's Avatar
Is this difficult? What basically has to be done? How long will it take to do?
Old Dec 17, 2006 | 09:22 AM
maximariceboi's Avatar
download the fsm online. www.phatg20.net
removing it shouldnt be that hard either.
Old Dec 17, 2006 | 10:09 AM
jxkim's Avatar
lots of bolts. half of mine broke due to rust. be prepared for this issue.
should take 1.5 hrs to 2
Old Dec 17, 2006 | 10:49 AM
MDeezy's Avatar
jack up the rear and look, you'll see where it connects and the bolts holding it on.
get a 10mm ready, not hard just remove the bolts and try to remove, any tension a bolt might still be on trace it and take it off. shouldnt take longer than 30mins
Old Dec 17, 2006 | 11:41 AM
urmab's Avatar
What he said!!! its not hard maybe it will take you anywhere from 30-2h depending. Its just a lot of bolts and you defiantly need patience. With that its easy.
Old Dec 17, 2006 | 12:18 PM
jxkim's Avatar
30 mins is bs. lol. i mean im sure ppl can, but my estimate was given this is your first time. yea i think youll need 10mm and a 12mm
Old Dec 17, 2006 | 04:54 PM
chillin014's Avatar
lol wtf i did this in like 20- 30 minutes, what are you guys doing taking a break after every bolt?
Old Dec 17, 2006 | 08:36 PM
nsnrider's Avatar
there are 6 - 10mm bolts on buttom, 3-12mm on each side inside the q-panels, plastic clips on top of cover, might want to take out tails to get to the two clips under tails per side or take out the bracket that holds the cover by taking out the 2 - 10mm on the inside of the back panel. Should not take you more than 40 minutes for a newbee and no more than 10 minutes for someone with experience. (Like me )
Matt93SE
May 24, 2019 02:58 PM
JoshG
21
Sep 4, 2015 09:04 PM
steven4838
Aug 26, 2015 11:04 AM
laflyer23
Aug 22, 2015 10:04 PM
maxipower
Aug 21, 2015 11:10 AM
