car not feeling like it should be
Well for one thing I don't feel the low end torque anymore... well at least not as much as I use to when I had an automatic, is there anything I can do to bring my car's torque back to par?
I'm having the same issue. I have replaced or religiously maintained everything listed above. My low end torque just sucks. The mid to upper range is fine and pulls hard but not the low end. When I first got the car and punched it in first from a stop, it would spin tires but not anymore unless I floor it at around 4000 rpm.
Originally Posted by ethnic6
would seafoaming the car help?
how do I check the PCV, MAF, and Coil packs (sorry I"m a complete newb when it comes to cars)
how to change the PCV is in the Haynes manual. and I believe there is a sticky for the MAF but i'm not sure if not its in the haynes manual too (where it is and how to replace it) the coil packs are whats connected to the spark-plugs under the cover in the front and along the back of the motor, there are 6 of them).
good luck
so basically i seafoamed my car yesterday at my garage, and man what can i say....ive never seen so much thick white smoke coming out of a car like that. After about 5-10 mins or so, i let the car run, and took it out for a drive, and it did feel a bit smoother, but still no change of the low end torque. Today, i did a complete tune-up (Spark Plugs, PCV Valve, Gas Filter), and i had cleaned the throttle body. As soon as i leave from my garage ill let you know if there was any difference. The PCV Valve was CLOGGED, and so was the Gas Filter, and the plugs were 50/50. I ordered the IACV, but i probably wont end up needing it unless the start up problems dont go away. But it does feel smoother, and somewhat quieter.
how do u go on removing the coil backs, doesn't sound very accessible to me...
Lakersallday24
06-16-2019 02:35 AM
MaximaDrvr
08-19-2015 09:20 PM
MikesChevelle
08-14-2015 01:31 PM
kirkhilles
08-08-2015 11:53 AM
