Possible injector failure
Old Dec 17, 2006 | 01:13 PM
idriveamaxima's Avatar
I was driving my car and it started idling and accelerating weird. It shakes when i caccelerate and a little bit when in idle. Out of the muffler u hear sounds like pf pf pf pf pf pf pf pf pf.....I dont know what exactly it is, but i think its one of the injectors. Anyone have any idea how to diagnose a problem like this? Its a 95 so i cant scan it
Old Dec 17, 2006 | 04:36 PM
2da mizzax's Avatar
Originally Posted by idriveamaxima
....pf pf pf pf pf pf pf pf pf.........
i was actually sounding this out. why would you think this is a bad injector? My first though would be a shot plug or 2. then perhaps a bad coil pack. any codes?
Old Dec 17, 2006 | 05:23 PM
madisonmxma's Avatar
You can hook a scanner up to it, it's OBDII, but there might not be any codes. If you had a bad injector, it would be more like a misfire than a constant pf pf. If you think it's fuel related, you can unplug each injector one at a time, and if one cylinder does not change the way it runs, that would be the bad cylinder.
Old Dec 17, 2006 | 06:59 PM
There are no codes, i changed the spark plugs and it still does it. I went to auto zone to get a free scan but there's no plug for the scanner. I dont want to change my wires because i want to be sure of the problem.
Old Dec 18, 2006 | 05:04 AM
pmohr's Avatar
No more Maximas...
You have a VQ, you don't have plug wires. there is a diagnostic port in passenger footwe side of center console.
Old Dec 18, 2006 | 06:18 AM
shilov's Avatar
An OBD2 port on my 1996 SE is under the treering wheel a bit to the left. Is there another one on the passenger side?
Old Dec 18, 2006 | 09:44 AM
the OBDII port is on the passenger side behind a panel, and if you get it scanned you will have to enter the vehicle as a 96.
Old Dec 18, 2006 | 09:47 AM
f550maranello2's Avatar
ohm out the injector...... if it says overload then its bad... u want somewhere betoween 11-14 ohms..
Old Jan 2, 2007 | 01:58 PM
turns out that it was the injector. it was the one closest to the throttle body. i switched it out and its all good now
Old Jan 3, 2007 | 12:12 PM
mbandit's Avatar
Did it run ok at high rpms, or did you not try that. I have a similar problem but the car idles good and doesnt miss at higher rpms but has a slight hesitation at about 2000rpms. I was thinking about trying to have the injectors cleaned.
Old Jan 3, 2007 | 12:48 PM
no it didnt run good at higher rpms either, it still didnt work. now it works tho so im glad i changed that myself and saved me a ton of money
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
