rims width question
Old Dec 19, 2006 | 01:23 PM
trialt's Avatar
rims width question
i found some rims that i would like to put on my car but unfortunately they are 19x9.5 and 19x10.5 just wondering if they would fit if if i pounded out the fenders a little?
Old Dec 19, 2006 | 01:34 PM
MaximaSE96's Avatar
Maxima Owner
depends on the offset....larger offset the more they will be tucked into the fenders....generally 10.5" IMO is too big 9.5" is stretching it as well IMO
Old Dec 19, 2006 | 01:38 PM
White Shadow's Avatar
Still chugging along...
I think those are going to be way too wide. I have 8" w/ 33mm offset and they are a bit wide. What's the offset on them?
Old Dec 19, 2006 | 01:44 PM
trialt's Avatar
+15front/+25 rear and i messsed up a little theyre actually 19x9/10 not9.5/10.5
Old Dec 19, 2006 | 02:48 PM
MaximaSE96's Avatar
Maxima Owner
wit that offset they are gonna stick out good
Old Dec 19, 2006 | 03:09 PM
TunerMaxima3000's Avatar
you might get away with 10s but you'd definately need to stretch the fenders out, biggest issue would be tie rods, etc, becuase you'd likely want the 10's up front(FWD)
consider a skyline usually has 10s to 10.5s and look at the fenders
Old Dec 19, 2006 | 03:28 PM
trialt's Avatar
hmm so should i put the 10's up front and 9's in the rear?
Old Dec 19, 2006 | 03:38 PM
personnaly i wouldnt put different sized rims on a street car unless it was RWD, but I also know you are going to have problems putting a rim of that size and offset on this car, did you get teh rims for cheap, are you just looking at getting them off another car? either way if you want those rims on this car it's gonna take some work.
Old Dec 19, 2006 | 03:41 PM
trialt's Avatar
well its just a certain rim that i want. it is pricey though.. but it would be nice.. about 3.8k with tires
Old Dec 19, 2006 | 03:42 PM
Wassup2114's Avatar
Damn, that's about what I paid for my car...
Old Dec 19, 2006 | 03:45 PM
LOL holy fuak dude, do they suck your caaak while you drive? For that price, plus the fab and body work, unless you are STACKED with cash I wouldnt do it IMO
Old Dec 19, 2006 | 04:01 PM
trialt's Avatar
well i already spent like 10k+ in upgrades etc so i mightasweel finish it off =P and make it how i want it
Old Dec 19, 2006 | 05:19 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
what kind of rims are they?
Old Dec 19, 2006 | 05:37 PM
trialt's Avatar
AME circular R
Old Dec 19, 2006 | 09:00 PM
You're better of getting wheels that actually fit your car. Those don't. Choose again.
Old Dec 19, 2006 | 11:54 PM
thomas.989's Avatar
Well I have 19/8.5 with a 38 offset and they are fine. The back rubs with weight in the car. I have 245 35 19 tires on them also. They are fine. I hope the tires are not to wide when I drop the car. But I didn't knock the rear fenders in yet.
Old Dec 20, 2006 | 10:02 AM
As you said, you already have a rub with weight in the car. If you drop that car, you will have serious issues if you are already rubbing. Also, he said his offest was +15 and +25. You have 13mm more offset than those wheels the OP is considering. If he has those tires and drops the car, problems will ensue with rubbing as well as having the susension geometry badly thowed off.
Old Dec 20, 2006 | 10:19 AM
MaximaSE96's Avatar
Maxima Owner
That 1" in width and 8mm in offset make a big difference
Old Dec 20, 2006 | 10:21 AM
AlpineGt66's Avatar
Originally Posted by White Shadow
I think those are going to be way too wide. I have 8' w/ 33mm offset and they are a bit wide. What's the offset on them?
nahh 8'w/33mm offset are perfect!
Old Dec 20, 2006 | 10:33 AM
You know I meant 8" doofus!
Old Dec 20, 2006 | 05:54 PM
thomas.989's Avatar
Well for the rubbing problem that i have is from driving in New york city pot hole city streets. The outside part of my tire rubbed the rear fender. The inside is clear with no rub marks in the wheel well. When I drop the car next month, I would let you know what da deal is. If your worried about 19 inch wheels, Ask someone that has 20's with a drop how there car rides.
Old Dec 22, 2006 | 01:41 AM
AlpineGt66's Avatar
lol. I knew you meant that! I didn't even see that myself till now. that’s not what i meant. I just put the 350Z wheels on my car, with 17x8 all around. and it looks good. I am just wondering if I can fit wider rubber than 235/45/17 on them? IMO the 235/45/17 are perfect on the speedo though!
i noticed a louder, stiffened ride switching from 16's to 17's, I feel bad for you guys with 18's+. I am not going up in size. 17's are a perfect balance between comfort/looks/ and most important performance in my opinion for the max.
mpbclutch33
Sep 21, 2015 01:54 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
adamgalazka
Sep 8, 2015 01:27 PM
