Putting the tranny back to getther FINALLY!
Old Dec 19, 2006 | 07:11 PM
Keith P's Avatar
Does anyone know the length of the bolt that holds in the checkball assembly that controls the shift forks rods on the manual tranny? With no compression, it appears to be 20 mm. But, I remember some spring compression when I disassembled the tranny.
The more expensive the repair, the more annoying the part.
Old Dec 20, 2006 | 09:08 AM
dgeesaman's Avatar
Maintenance Monster
The bolt is a little more than an inch long, with a 14mm head. The spring is a good 1-1/2" or more long.
Don't forget there is one last check ball that goes in before that spring.
Dave
Old Dec 20, 2006 | 07:03 PM
Keith P's Avatar
The spring and ball are in the hole. Good use of tape. I measured the spring at 55 mm. Just short of 2 inches. With the gears in neutral, the remaining depth is just shy of 20 mm. I guess no other spring presure is really neccesary.
Thanks for the shout.
JRod28
Dec 29, 2023 09:56 PM
seesole
Aug 26, 2015 11:22 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
maxinout93
Aug 16, 2015 07:25 PM
sc10692
Aug 9, 2015 09:37 AM
