Idle too high
Idle too high
Hey guys I had my auto converted to a 5 sopd about 8 months ago and for all this time everytime I put it into N my rpms would stay at 1.6 until i would coem to a complete stop and hten after 3-5 secs wuld drop to .7. I know it is most likely because of my auto ECU, however I cleaned mt TB yday and now rpms are sometimes a little higher - 1.7 and are high when they car is cold. Therefore I was thinkin maybe there is a sensor near TB that I can just disconnect so my ECU will not be sending signals to keep RPMs so high?
Well when cold u can expect high rev at start up and for a couple minutes after that. Cleaning your throttle body will also raise it as you know. It might be because ur AUto ecu because your manual transmission has a lot less going on then a auto would while in manual. 5 speed= free spinning while auto still has funstioning components.
if that helps any.
if that helps any.
if that helps any.
if that helps any.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
