Cracked rear main seal, HELP
Old Dec 27, 2006 | 07:27 AM
kismias7's Avatar
I am leaking oil because my rear main seal is cracked. I have been losing about a quart a day and replacing it. The oil drips down and burns on my exhaust and causes my car to smoke a lot.
To get this fixed does the tranny need to be dropped? I have been told only the clutch needs to be removed, and now this guy is telling me the whole transmission needs to be dropped. Please help.
Old Dec 27, 2006 | 08:51 AM
Pieps's Avatar
You have to remove the transmission to get to the clutch to remove it
Old Dec 27, 2006 | 08:56 AM
ComradeJew's Avatar
Yup. If you gonna swap your rear main seal, might as well swap your clutch...
Old Dec 27, 2006 | 09:04 AM
i30ds's Avatar
Armed and Dangerous
If the clutch has to be removed, the tranny has to be removed.
In order to PROPERLY replace the rear main seal, the tranny needs to be dropped, clutch and flywheel removed, y pipe removed, and bottom end dropped.
Old Dec 27, 2006 | 12:28 PM
getbigtony's Avatar
yea, that; or do a motor swap!
time to get a vq30-dek!!
EDIT: just saw u live in philly; the dek would be kind of expensive, and hard to come by
you should go to the passyunk strip and check the junkyards there to see if there are any of your motors sitting there
may be better if you find a nice low mileage one
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
steven4838
Aug 26, 2015 11:04 AM
raffivegas
Aug 23, 2015 09:54 PM
