Need Help Fast: Rear Brake Job...
Old Dec 30, 2006 | 09:50 AM
petemo95se's Avatar
Folks,
In the process of doing my rear brakes. I've hit a snag and need your help.
1. Is there a tool to use that compresses the brake piston? I am using a wood clamp that is working, but I'm beating the heck out of the clamp and am bending it.
2. When I compress the piston, the rubber grommet around it is just folding up. Normally the rubber will compress into a normal looking shape. But this time, it's just folding up, looking like it's going to split/burst. Is this normal?
I don't want to split it or break it. Any help would be great.
Old Dec 30, 2006 | 09:57 AM
Mxrider52's Avatar
I support for what?
Stop that now!!!! You must twist the piston back in.
Old Dec 30, 2006 | 10:10 AM
the_3d_man's Avatar
turn the piston to get it to go back in. You can not just push it in like the front brakes. It helps a lot to go get the tool from autozone or similar store. It costs about $10 and they will kno0w what you are talking about if you ask them for it. (turn it clockwise to make it go back in)
Old Dec 30, 2006 | 10:19 AM
JwaxMax99's Avatar
Then, if the piston won't turn in, you have seized-up calipers, pretty common on the rears.
Old Dec 30, 2006 | 10:43 AM
madisonmxma's Avatar
I wouldn't really recommend it but you can use a needle nose pliers and twist it back in, but that's if you have no other option.
Old Dec 30, 2006 | 06:38 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
^I would recomend it. Its easy and there is nothing wrong with doing it that way.
Old Dec 30, 2006 | 07:08 PM
i30dvr's Avatar
same, i did this last time i did my brakes and it worked fine
Old Dec 31, 2006 | 03:32 PM
petemo95se's Avatar
Complete!
Folks,
Thanx for the help! I actually got the tool at the auto part store for $8. I agree it was NOT really required, could have done it with needle nose plyers. but the tool worked fine.
Also, had a heck of a time with the 2 brake. You MUST align the piston at 3-Oclock so that the little notch on the brake pad lines up with the notch in the piston. Otherwise the bolts for the torque member will NOT align. I spent about an extra 40 minutes until I figured this out.
Thanx again for the tips!
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
