The Best tools for KS swap?
Old Jan 1, 2007 | 10:57 PM
ArcticW's Avatar
Im gonna be picking up some tools soon,so what wrench and extension works the best with knock sensor removal? I know how to change it,just want the right tool for the job.
Old Jan 1, 2007 | 11:10 PM
J_Ketzer's Avatar
The best tool is a 12mm, 1/4" drive flex socket attached to a long (at least 10") extension. With this setup I had the old sensor out in under five minutes.
You can also just use a U-joint and a regular socket, but I had some difficulty getting a 3/8" U-joint in there. I'm sure it's doable.
Old Jan 2, 2007 | 03:56 AM
mastercater7's Avatar
VQ35 FTW
you need a lady friend or small child with small hands. thats how i (we) did mine. regular ratchet with 12mm socket. 5 minutes.
Old Jan 2, 2007 | 07:20 AM
chillin014's Avatar
isnt this in the stickies?
Old Jan 2, 2007 | 06:11 PM
happy4444's Avatar
it should be b/c i need to change mine soon and was gonna ask this sooner or later
Old Jan 2, 2007 | 06:54 PM
ArcticW's Avatar
The stickies are great at showing HOW to change the KS,but with what tool to use was kinda random choice..
Old Jan 2, 2007 | 07:06 PM
Sloppy Snood's Avatar
Honestly, it's probably not in the stickies because most DIYers know how to use a socket, extension, and a ratchet. Not trying to be a smarta$$, just stating it like it is.
Old Jan 2, 2007 | 07:56 PM
aznstormin's Avatar
good info.. now i can go get the right tools and finally replace mine..
Old Jan 2, 2007 | 09:54 PM
MrDicks95SE's Avatar
Offset Is Everything.
+1 on the small hand. the only problem even with a small hand is that green plug that gets in the way. my hands are always scratched and bleeding from that damn thing. but i got it down really good. also useful is one of those retracting magnet antenna.
Old Jan 2, 2007 | 10:14 PM
KRRZ350's Avatar
my weapon of choice is a 12mm gear wrench, undo the top of the green connector that gets in the way, wiggle your hand in there and get it cut like mr****s said, then hand yourself the wrench AFTER your hand is in there (do the same with the new and old ks)
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
