relays.
Old Jan 4, 2007 | 06:56 PM
shissqbob's Avatar
relays.
Hey guys, quick question. Do any of the relays next to the fuse panel or under the hood affect the interior lighting by any chance. there's the central lock relay and then misc. ones.
Also, i went outside to check the voltage coming from my ignition ring light. it was reading around 3 volts i believe, super low...i noticed the dome light (when it's switched to come on when doors open) and the key light are significantly dimmer.
Any help would be great.
thanks
Old Jan 4, 2007 | 07:35 PM
MaximaSE96's Avatar
Maxima Owner
i dont beleve there are any relays that control the interior lighting...any fuse or relay that went bad would totally kill the lighting ..u might want to check ur battery......it may be fine when driving because the alternator is charging the battery but sitting it could be losing voltage kwiker than normal
Old Jan 4, 2007 | 07:57 PM
shissqbob's Avatar
oh alright, i'll try that. now that i remember, I never did check the lighting when the car was on. thanks a lot.
the only thing im confused about is: the lighting is brighter on the dome light when the switch is in the ON position. when the switch is in the MIDDLE (doors open it goes on) position, the lights are dimmer, looking like they have less power.
LastTraintoMEM
Apr 25, 2014 03:22 PM
Specd_out
Jun 15, 2012 12:13 AM
BigLou93SE
Apr 22, 2005 10:13 PM
Adrian112597
Dec 17, 2004 04:27 PM
