Can I mount 18 x 8.5 wheels on my Max??
Old Jul 3, 2001 | 12:19 PM
cmcknite's Avatar
The wheels that I want are 18 x 8.5. Can I mount them? If so, what tire size? Help!
Old Jul 3, 2001 | 03:10 PM
Ravq's Avatar
The answer is yes with the correct offset. Talk to Chunger he's running 245/40s on his 18x8.5s. I think is offset is somewhere between 35-40mm. IMO that's too wide and it will stick out in the front a little.
Old Jul 4, 2001 | 01:23 AM
Chunger's Avatar
My other car is a Hybrid
35mm offset but you can probably go 38...maybe 40 (possible you may rub on a full turn)...
Even with 35mm and 245s it doesn't stick out too much... look below... I do have those wheel well "stick ons" though that kinda extend the width 2mm or so...
Old Jul 4, 2001 | 11:55 PM
1/3There2/3ToGo's Avatar
If you are going to be running 18x8.5's you should go with 245/40/18 tires. The 245 will be wide enough and the 40 will make it so that your speedomiter will only be off by .355 - it will say you are going 100.355 mph when you are actually going 100 mph.
K
dank4us
34
Jun 10, 2024 03:45 AM
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
