Rear camber problem
Old Jan 8, 2007 | 08:15 AM
cardana24's Avatar
Blown
Rear camber problem
I just got my 95 Maxima back from the alignment shop and my rear camber was negative. -1.0 (left) and -1.1 (right). What can cause this? I do an aftermarket RSB on the car that I tightened while the car was in the air...I don't know if this would really affect anything but just thought I would mention that. I am lowered several inches on Ground Controls and AGX's. Why would my rear camber be negative? What would cause this problem? Thanks for any help.
Old Jan 8, 2007 | 08:44 AM
fithos's Avatar
I would remove the rear wheels and tighten them again with a torque wrench. Then take the car to a different alignment shop for a second opinion. Sometimes those alignment machines are off. Did you add something to the rear lately, like wheel spacers?
Old Jan 8, 2007 | 08:58 AM
cardana24's Avatar
Blown
no wheel spacers. I have the suspension mods that I listed. I took the car for alignment because I had raised the car for the winter and put the stock wheels back on. In the summer when I have it aligned I put the ground controls all the way down in the front and match that in the rear (not that, that matters)
Old Jan 8, 2007 | 09:09 AM
Dubbya's Avatar
VK56 Inside
for the machine being off. That happens a lot.
Old Jan 8, 2007 | 09:42 AM
cardana24's Avatar
Blown
that could be the case. This is a pretty busy shop though so I imagine they would keep on top of their equipment. It does seem odd to me that the camber readings on each side of the rear were ~ the same. It would make more since if one side was messed up from being in a wreck or something. The car does track straight since the alignment so whatever they did in the front seems to be right.
Old Jan 8, 2007 | 10:12 AM
RA030726's Avatar
I'm nutty for Nissans
There is no way you can have camber change with our rear beam, its solid. Unless your bearings are worn out or the beam has been damaged its fine.
Old Jan 8, 2007 | 03:35 PM
fithos's Avatar
In that case why don't you ask them to turn the car around and back the car in. Use the machine's front alignment for the rear. I have asked and seen alignment shops do that before.
Old Jan 8, 2007 | 04:25 PM
njmaxseltd's Avatar
REAR WHEEL ALIGNMENT
Camber, in degrees
-1.75 Minimum
-1.00 Nominal
-0.25 Maximum
Total toe-in distance, in millimeters
-3 Minimum
+1 Nominal
+5 Maximum
Total toe-in angle (left plus right), in degrees
-0.27 Minimum
+0.09 Nominal
+0.43 Maximum
Your car is tracking correctly.
There is nothing wrong with your rear camber, it's right on the money.
Old Jan 8, 2007 | 04:54 PM
the_3d_man's Avatar
I was wondering if someone was gonna post that. lol
If you had positive camber, then you would have a problem.
Old Jan 8, 2007 | 07:54 PM
cardana24's Avatar
Blown
oh ok cool. I did not know that and I guess the guy at the shop did not either because when I went to pick the car up he circled the two rear numbers and was telling me that they were off. Oh well....that's good to know there is nothing wrong.
Old Jan 21, 2007 | 09:47 PM
venturous's Avatar
I would be tempted to go back to the shop and ask the guy where he got his figures. I would not trust that he knows what he is doing on a Maxima.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
homeyclaus
Sep 3, 2015 06:15 PM
Mcnabb34
Aug 11, 2015 08:45 PM
