Snapped a lug nut stud...what now?
Old Jan 12, 2007 | 04:27 PM
bearded's Avatar
I just broke my lug nut off with part of the stud still in it while trying to take my tire off. Is this a hard/expensive fix? Should I even bother trying to take it to the shop that put the lug nuts on crooked and have them fix it? Thanks.
Old Jan 12, 2007 | 04:32 PM
NmexMAX's Avatar
dot dot dot ...
Go to autozone, buy a new stud, install it.
Not more than $5, take wheel off, bang them out, put new one in its place, tighten the lug, loosen the lug, tighten again, loosen, then install.
Old Jan 12, 2007 | 04:51 PM
bearded's Avatar
Thanks for the reply NmexMAX.
So you can just bang the studs out with a hammer? I install the new stud by screwing in and tightening the lug nut?
Old Jan 12, 2007 | 04:56 PM
NmexMAX's Avatar
dot dot dot ...
I usually use an old shirt/rag and put it over the hammer. Or just use a mallet.
Had a headache after I changed all my studs one day :
Old Jan 12, 2007 | 05:22 PM
MaximaSE96's Avatar
Maxima Owner
stop ur whining.....I had to do all my fronts for install of longer ones.....its not bad
Old Jan 12, 2007 | 05:28 PM
nismology's Avatar
Agreed.....whiner...
An impact wrench makes the job so much easier.
Old Jan 12, 2007 | 06:30 PM
86maxima96's Avatar
I Broke OT
can't it be bad to hammer on the joints/axle like that?
Old Jan 12, 2007 | 07:49 PM
J_Ketzer's Avatar
Find some washers which fit around the new stud, too. The stud will probably be too long to pull through with just the lug nut, so you can stack some washers on it. You'll see what I mean when you put the new one in.
Old Jan 12, 2007 | 08:22 PM
MaximaSE96's Avatar
Maxima Owner
yeaaaaaaaaaaaaaa......oh yea the washers is a def.
Old Jan 13, 2007 | 12:46 AM
nguyen925's Avatar
if you dont know what your doing just buy the studs at autozone or something and get a body shop to replace them/it for you. it shouldn't be expensive..
Old Jan 13, 2007 | 11:38 AM
NmexMAX's Avatar
dot dot dot ...
Yup.. whining again .
I had to do all 20
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
dcam0326
Sep 26, 2015 05:20 AM
camako
Sep 22, 2015 04:27 PM
