Crazy amount of fumes and smell from exhaust
Old Jan 14, 2007 | 02:44 PM
99MAXSE-L's Avatar
Ive began to realize the amount of fumes and smell thats been coming from the car right when its been started up. While i wait for it to warm up, theres a cloud of fumes/smog or whatever along with a slight smell of some sort.
I dunno what it is or how to fix it somehow. Would any type of cleanerr, like fuel injector cleaner work?
Old Jan 14, 2007 | 05:14 PM
foxracing12's Avatar
How does the engine run/idle? Are the exhaust fumes a certain color (white, bluish, etc). Does it go away quickly?
Old Jan 14, 2007 | 06:01 PM
99MAXSE-L's Avatar
car is smooth, exhaust fumes are white. Doesnt really go away quickly, they r like clouds
Old Jan 14, 2007 | 06:15 PM
2da mizzax's Avatar
head gasket. check your rad level. and before people chime in telling you to buy a new motor there are means to seal the leak that are relatively inexpensive.
Old Jan 15, 2007 | 05:16 AM
njmaxseltd's Avatar
Perfectly normal to see your exhaust on a cool day. It's called condensation, a by product of combustion. It smells a bit because a cold engine runs rich until it reaches normal operating temp.
There is nothing wrong with you car.
Old Jan 15, 2007 | 11:16 AM
323MaximaSE's Avatar
Same thing happened to me the other day. I started my car at about 6am and it was about 50 degrees outside. There was a huge white cloud coming from the back of my exhaust. But if you just let your car warm up for 5-10mins the smoke will disappear and the fumes will go away.
Old Jan 15, 2007 | 11:22 AM
2da mizzax's Avatar
Originally Posted by 323MaximaSE
...... There was a huge white cloud coming from the back of my exhaust. But if you just let your car warm up for 5-10mins the smoke will disappear and the fumes will go away.
Condensation usually goes away quickly. A minor head gasket leak will smoke until the coolant in the oil has burned off so just because it stopped does not mean there isnt a problem. To be safe, check the radiator (not just the resevoir bottle). If it isnt full as it should be, time to do some more investigating.
Old Jan 15, 2007 | 11:30 AM
vipervadim's Avatar
I like Maximas
do you have a catalyctic converter or a straight pipe in your exhaust?
Old Jan 15, 2007 | 04:23 PM
99MAXSE-L's Avatar
catalyctic converter...theres alot of condensation, but i guess its normal. Whatever, car seems to be running like normal. Just thought id pop the question here.
Old Jan 15, 2007 | 05:47 PM
is it normal for your car to initially idle at 1.2k then go back to 750?
Old Jan 16, 2007 | 07:47 AM
willard00's Avatar
are you serious?
Old Jan 16, 2007 | 01:33 PM
what should i do to fix this? Everytime i start my car the idle goes over 1k then after 2mins it idles at 750
Old Jan 16, 2007 | 02:17 PM
bigpulve+'s Avatar
That is very normal. You have nothing to worry about.
Unclejunebug
Apr 2, 2016 05:42 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Garrettz459
Sep 28, 2015 02:50 PM
Socalstillen
Sep 26, 2015 12:01 PM
