Changing front crank seal
Mine's starting to seep a little oil, so I intend to pull the crank pulley and change this.
I figure my electric impact wrench should loosen the nut, I might need my 2 jaw puller to pop the pulley free, and then I just pry out the old seal and tap in the new one.
Is it really that simple? Any tips appreciated.
Dave
Dave
My electric does 320ft-lb when fully charged. I should probably work with some penetrating oil first.
The FSM says to tighten to 30ft-lb, then another 1/6 of a turn. Dunno exactly what torque that will be, but probably reasonable.
Dave
Dave
what kind of elect impact do you have? do you use it for things like removing lug nuts? I ask because I bought one a while back that was rated for 275ft-lbs and it could not even spin off lug nuts so I returned it.
anyway - please keep us posted on your results. I too might try to replace that seal.
Ingersoll Rand IR 2530. http://www.irtools.com/IS/product.asp-en-2868.
It easily does lugnuts on my truck, and I trust it will handle axle nuts too. I cry tears of joy when I think about it. (I don't have space/neighbors for an air compressor)
Dave
Dave
a few more thoughts on this...
- I think you have to remove the crank pos sensor before you pull the pulley.
- I've never used a seal puller before so I don't know how they work. but you do no want to just "pry" at the seal with a screwdriver though. what you need to do is punch the front edge of the seal with a hammer & punch (or slotted screwdriver) so as to compress its circumference ever so slightly. this will make it much easier to remove. or just get the proper tool.
kjlouis
Nov 24, 2018 06:09 AM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
