Strut Mounting bearing replacement???
Old Jan 17, 2007 | 08:36 AM
Stagnet04's Avatar
I wanted to see if anyone has done this. Im about to change both of them in the front suspension because after I put on my illuminas and progress springs Im getting that "Clunking" noise when I turn to much. I found the website on how to do it, http://www.motorvate.ca/mvp.php/703 but it says to "Be careful on what type of grease you use", but never says which one he used. So for the people that have done this replacement, do any of you know what type of grease I should use? Like a brand name? or a special type?
Thanks...
Old Jan 17, 2007 | 08:38 AM
ThurzNite's Avatar
Towards the bottom of the website u posted, it reads:
UPDATE:
Do not try to re-grease the bearings. I did, and it lasted 10 months, and the same noise came back. Spend the $40, and it is fixed for the life of the car.
I bought new ones. I tried cleaning the grease off the old one cuz I didn't wanna mix old and new grease. But if you've used plastic containers to hold greasy leftover foods, you'll understand how difficult it is to get all the grease out. Even after I did that, I couldn't find any thin slick grease that would stay put... I was thinking of something silicon, but it wasn't as slick as the new bearing I ended up using. Sorry I can't be of more help, I can only recommend getting a new bearing.
Jae
Old Jan 17, 2007 | 08:48 AM
97SEdriver's Avatar
this place is dead
Thanks...
it doesn't say to grease the bearings....its says not to try and RE-grease the bearings....
Old Jan 17, 2007 | 09:02 AM
Stagnet04's Avatar
Yeah, I just saw that. I guess I interpreted it wrong. I just wanted to make sure that those that have bought the new ones didn't use grease, that they just replaced them straight up and it fixed the problem...
Old Jan 17, 2007 | 09:06 AM
MaximaSE96's Avatar
Maxima Owner
i never used grease but if i did u would use phil wood grease...i used to use it in my BMX days...its fantastic and waterproof
http://www.philwood.com/webcatolog/page18.htm
Old Jan 17, 2007 | 09:13 AM
Stagnet04's Avatar
oh ok, cool...
Old Jan 17, 2007 | 10:57 AM
phenryiv1's Avatar
Mod her. Ate her.
I used lithium several times and never had a problem. Don't remove the old stuff- just add lithium to it and re-install.
If I were you, I'd check to be sure that the springs are clocked correctly and that the top mounts are in the right position. We forgot to do that when we lowered the '00 and it was a heck of a racket. 15 minutes of adjusting the top mount to the correct position and all was well with the world.
Matt93SE
May 24, 2019 02:58 PM
seesole
Aug 26, 2015 11:22 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
