HID kit?
Old Jan 21, 2007 | 05:21 PM
maxedoutboi06's Avatar
HID kit?
One my headlights has a shortage in the wiring and my nissan place is charging way to much money to fix it, so I was wondering if I got an HID kit would it kinda fix that problem? I always wanted an HID kit but my stock wiring has that shortage which makes my headlight go out and its a mother to make it come on. I was thinkin an HID kit replace that wiring, guys help me!! Im going nuts over this stupid light!
Old Jan 21, 2007 | 05:41 PM
Dave H.'s Avatar
I dont' think getting a plug n play kit would help any. You need to have full functioning lights before you hook it up. If they don't work now, HID's won't work either. My HID kit just plugs into the light socket, plug and play. That is why you need them to work.
Old Jan 21, 2007 | 09:05 PM
U know where i can get stock headlight wiring? cuz my nissan place is charging 2 much and im sure i can do it by myself ( I hope)
Old Jan 21, 2007 | 09:11 PM
t65k3's Avatar
Still Learning
Do you know where the shortage is?
Dave, could you tell me where you got the AE headlight?
Old Jan 22, 2007 | 09:07 AM
MDeezy's Avatar
if its a short in a wire, the fix could be as easy as cut the wire and soldering in a new one, or even bandaging the old
Old Jan 22, 2007 | 09:13 AM
jltibbs's Avatar
they look like custom enterprise to me.
Old Jan 22, 2007 | 03:58 PM
Dave H.'s Avatar
They are from ebay. So pretty much the same as CE but cheaper. Look on ebay, you may find some. The new R34 headlights are kind of taking over though.
Old Jan 22, 2007 | 06:13 PM
jltibbs's Avatar
dave, someone asked me about them on ebay and they aren't on there anymore. makes me want to keep mine even more now since the R34's are taking over.
Old Jan 22, 2007 | 09:12 PM
jvelos3's Avatar
make a relay connecting the power directly to the battery and use the good bulb socket as the switch...should cost no more than $20
Old Jan 23, 2007 | 08:27 AM
Its the plug to the light bulb, its just about burnt up. So Im gettin a new one, then Im going to look for an HID kit.
Old May 5, 2007 | 02:41 PM
2kMaxEma's Avatar
2k Maxima - Melted Connecter on Factor Headlight
I seem to also have a melted connected for my factory original headlights; no idea how I could melt factory connector on factory bulb. Regardless, I now need to figure out where/how to replace the stock connector; my dealer tells me he can't get the connector only (a pigtail)....he can only get the entire friggin' harness @ $1200+. Can you say RIP-OFF!!!. I'm going web shopping....
Old May 5, 2007 | 09:41 PM
FantasyGod's Avatar
HID KIT DOES NOT REPLACE FACTORY HARNESS! Don't be foolish, the HID kit will only make it worse. The ballasts from a HID system require constant, steady power or else your bulbs will flicker like strobe lights. In this case, you bulbs and ballasts will both fail shortly and you would have wasted $200-300 on the HID kit and still be stuck with a shorted out harness. This is on top of the fact that plug and play HID kits without a relay harness may cause the factory wiring to melt. Even with a relay harness, your headlamp wiring doesn't seem to produce enough juice to steadily keep the ballasts properly powered. There is no way around except to replace the factory wiring harness or if you know anyone proficient enough to wire your own harness around the existing failed wiring. Any shop that installs aftermarket foglights can help you bypass your factory wiring.
Old May 5, 2007 | 09:44 PM
FantasyGod's Avatar
http://www.rallylights.com/hella/Connectors.asp
You need the male 9004 plug but this is ONLY if your connector is melted and the rest of the wiring is still good.
Old May 5, 2007 | 09:55 PM
maxima985spd
Tell the dealer to find out exactly where the short is in the wiring harness...the repair it with a new piece of wire
Old May 5, 2007 | 11:54 PM
sublimeskunk's Avatar
go to autozone, buy 9007 aftermarket wiring for like $5, do 9004 --> 9007 mod
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
