Need Help, Searched "How To"
I'm going to be replacing my drivers side and passanger side mirrors ( i was backing up into my garage and took one off ) but i never did this, so i was wondering what tools i need and how to do it. if anyone has any info on it. and also i will be repalicng my antenna cuz its broken i would also like to get as much info on this as well. or if anyone from the chicago land area wants to help me ill be more then welocme to pay you.
Thank you.
Thank you.
for the mirrors all you need is a couple screw drivers to get the door panel off then probably a 10mm socket to finish the job.
all you have to do it take off the door panel: there are two screws on the bottom of the door, then one in the little cup you use to pull the door shut, take out the window controls, and the cup behind the door opener handle.
take off that little black sail panel then the bolts holding the mirror on are behind there.
hope that helps, i cant help with the antenna though
AaronL
08-08-2020 10:31 AM
06-06-2017 02:01 PM
