Cant get the corner/clearance light assembly out
Old Jan 25, 2007 | 08:17 PM
andrei3333's Avatar
I Changed my headlight bulbs recently and wanted to change the corner lights (the onces that are located right beside the headlights and have the clear glass)
i unscrewed the screw but tried to wiggle the light housing out and could not get it out, i cant understand how its attached from the bottom on the inside. it seems that the part where u screw it to the car is interfering with me being able to take it out
i wanted to put blue bulbs in there at first, but then i hear u can get a ticket for that, so i wanna put some yellow bulbs there, it will match my parking lights (i dont have clear corners)
How do i get it out ?
Old Jan 26, 2007 | 12:14 AM
Spartuss's Avatar
I as well had problems taking the corner lights out and and than gave up.
Old Jan 26, 2007 | 05:05 AM
ALSOUSA99MAXIMA's Avatar
lol
Old Jan 26, 2007 | 05:24 AM
jxkim's Avatar
force it. after years it has never been removed. just put some strength into it.
Old Jan 26, 2007 | 05:33 AM
MaximaSE96's Avatar
Maxima Owner
use a flat head screwdriver with rag over it.....i believe thats even in the owners manual
Old Jan 26, 2007 | 05:36 AM
maxprivate's Avatar
Black Lion
you have to pull towards you really hard. once you have the screw out on top of course. id seems like you will break it but you wont.
Old Jan 26, 2007 | 05:38 AM
wuzzy's Avatar
^^ That is what I did. right one came out np, left one had to put a little effort into it. But dont break anything when you try to press hard
Old Jan 26, 2007 | 07:46 AM
andrei3333's Avatar
what bulbs should i put in there: yellow (to match my turning signals) or Blue (to get pulled over and get a ticket)
my headlights are super white (not blue) bulbs by Sylvania; Silverstar Ultra
Old Jan 26, 2007 | 08:02 AM
jacobmh27's Avatar
I tried this too and thought I was going to break them and they came out ok
Old Jan 26, 2007 | 08:27 AM
andrei3333's Avatar
It seems as thought as the part where the screw hold it down is interfering with me pulling it out. Which way should I pull the light? I dont understand what is holding it from the inside
Old Jan 26, 2007 | 09:04 AM
|3ourne's Avatar
at the base of the clearance light is a ball joint. Take a flat head screwdriver and while pulling the clearance light towards you push the screwdriver in the ball joint and twist it. If you do it right , it should pop right out. Just takes some strength to pull the lights wide enough to wedge a flathead in there.
Old Jan 26, 2007 | 09:13 AM
maxedoutboi06's Avatar
I have blue bulbs in mines to match my headlights. I have my clear corner bumper lights blue also, turn signals and park and I have been pulled over yet! well for my neons and loud music
Old Jan 26, 2007 | 09:15 AM
maximized98's Avatar
Addicted to the Org
yea, this is the hardest mod to do "change the corner bulb" mod. I didn't do this because of the difficulty. LOL
Old Jan 26, 2007 | 03:42 PM
Dave H.'s Avatar
Just to clarify, you push the corner light away from the side of the car, not necessarily towards you, example if you were in front of the car.
Old Jan 26, 2007 | 03:50 PM
andrei3333's Avatar
Maybe thats why i was having trouble, i just didnt want to chip the headlight with my screwdriver cause thats what i was using for leverage. it was wrapped in a cloth but still i think its possible to chip it. i will try again tomorrow, and I think i will go with the yellow bulbs.
Old Jan 26, 2007 | 04:10 PM
rockfordmaxII's Avatar
Just rip that ***** out!!
Old Jan 26, 2007 | 04:23 PM
jxkim's Avatar
i threw my weight into it like a football tackle. when it finally popped i almost fell
Old Jan 26, 2007 | 04:50 PM
Trajiksmax's Avatar
Proud Maxima Owner
Think of it as a Lambo door. LOL!!!!!
Old Jan 27, 2007 | 11:42 AM
Cdg2125's Avatar
Light needs to go towards the front of the car first then you can pull it out from the ball and socket. Put amber bubs and none of that blue ****. White would look ok too. If you don't get pulled over with blue lights then your cops are idiots.
Old Jan 27, 2007 | 11:51 AM
andrei3333's Avatar
no i dont want the blues, wont match my turning signals, so i am thinking yellow, right now the stock bulb is weird its like a cross between white and yellow, i cant explain its in the middle of those two colours, like a washed out yellow its pissing me off
Old Jan 27, 2007 | 12:03 PM
jxkim's Avatar
get chrome bulbs that light up amber
Old Jan 27, 2007 | 12:31 PM
Cdg2125's Avatar
yeah stock bulbs suck. Amber are the best. Gives some color during the day and lights up nice at night.
Old Jan 27, 2007 | 04:48 PM
ptatohed's Avatar
Licensed to Spell
:o)
Yes, I3ourne's advice was the best on here. No one else told you how it actually works! (It is a ball-in-socket design as I3 mentions) and yes, the best way to get it out is not by using a screwdriver externally (putting pressure on your corlner light and/or headlight), it is by coming down, from behind the light, putting the flathead driver between the light and the ball joint and then twisting in a corcscrew fashion. Good luck. The stock corner lights are too tight and the aftermarket diamond clear corners are too loose - mine always pop out now! You can't win.
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
I<3 A32's
Sep 10, 2015 11:07 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
