how many oil qts?
Old Jan 28, 2007 | 02:01 PM
jxkim's Avatar
how many oil qts?
just changed my oil yesterday and put in 4 qts of castrol gtx 5w30
today i checked the level and it seemed to be MAX or barely over. i was thinking it would be below and i would have to add some more. my friend told me i should put 4.25 qts. tried searching online but couldnt find anything.
on http://www.motorvate.ca/mvp.php/511
the guy put it 4 liters which is less than 4 qts if im right? help me out.
Old Jan 28, 2007 | 02:17 PM
kcryan's Avatar
Barley over your fine. I think it actually takes about 4 quarts.
Old Jan 28, 2007 | 02:22 PM
2da mizzax's Avatar
4.25 with filter change. (depending on which filter you install) and 4 litres is more than 4 qts.
Old Jan 28, 2007 | 02:33 PM
buzpuck11's Avatar
My car took 4 quarts with a filter change. I also used GTX5w-30.
Old Jan 28, 2007 | 02:36 PM
Sounbwoy's Avatar
4 liters = 4.226753 quarts
Old Jan 28, 2007 | 02:46 PM
jxkim's Avatar
used nissan oem filter
guys at pepboys were like "YOU NEED FIVE. its a v6" good thing i didnt listen to em
Old Jan 28, 2007 | 02:57 PM
willard00's Avatar
i used 5 quarts of gtx last oil change.
Old Jan 28, 2007 | 03:34 PM
kbmaxima's Avatar
5 qts? drain and refill correct amount
Old Jan 28, 2007 | 04:42 PM
willard00's Avatar
ive always used 5 qrts. read in more than one place that correct amount for our cars is 4 1/2-5qrts....dont know why everyone on here thinks its only 4?
Old Jan 28, 2007 | 04:45 PM
Fr33way™'s Avatar
Wild for Width
5 quarts will stress the seals.
Fr33way™'s Avatar
Wild for Width
And it is 4.25.
Old Jan 28, 2007 | 04:52 PM
kcryan's Avatar
FR33 is dead on with the 4.25
Old Jan 28, 2007 | 05:11 PM
jxkim's Avatar
5 qts is how much i put in my last car, crown vic v8 4.x liter engine.
but dont know why you would need more?? someone?
interesting, barely related point: dirty oil pan/engine? use some engine cleaning? u can throw in 1 bottle of transmission fluid instead of engine oil. it wont do any dmg and will slowly clean it out. i think you maybe have to do this for 3,000 miles more than once. heres the article: last part "the facts..."
http://autotechrepair.suite101.com/article.cfm/040206
Old Jan 28, 2007 | 05:20 PM
kcryan's Avatar
^Bad idea
I suggest Auto-Rx
Old Jan 28, 2007 | 05:22 PM
ImmaSquashYou's Avatar
everytime i change my oil i buy 5 quarts. I use mobil 1 fully synthetic with K&N oil filters. I put in 4 quarts. Drive around come back n check the dipstick. Usually put in about 1/4 to 1/2 quart.
Old Jan 28, 2007 | 05:26 PM
f550maranello2's Avatar
its 4.25 quarts MAX... thats all u should be putting in...
Old Jan 28, 2007 | 05:35 PM
Gismo-T's Avatar
B!tch We Got a Problem
Why, have you neglected doing your oil changes?
When I do mine, I use either Nissan or Napa Gold filter w/1 qt.
Lucas Synthetic Additive & 3 1/4-1/2 qts. Castrol GTX 10w30.
Old Jan 28, 2007 | 05:39 PM
kcryan's Avatar
Best method, after a bunch of changes you get a free one (minus filter) because of the leftovers
Old Jan 28, 2007 | 05:41 PM
kcryan's Avatar
When I do mine, I use either Nisson or Napa Gold filter w/1 qt.
Lucas is a no no, it has a tendancy to foam up, and fomay oil doesnt lubricate well. Their syn stuff is better, but still your better off without it, GTX is great oil and doesnt need anything (although i would put some LC20 in it, if interested google lubecontrol) Also, i would run 5-30 regardless of climate, it cant be too thin upon startup.
Old Jan 28, 2007 | 06:34 PM
Gismo-T's Avatar
I use Lucas maybe every 3rd oil change. (never had problems)
Have you ever tried LC20?
Old Jan 30, 2007 | 04:39 PM
rjtiobol's Avatar
Ive been using 4 qts for 204,000 mile.
wow 63 oil changes
Old Jan 31, 2007 | 07:04 AM
jxkim's Avatar
yea i dont know why but 4 qts topped it off for me. i had that extra .25 rdy but decided to go with the oil dipstick rather than the norm. you think its caused by some sludge buildup or something?
Old Jan 31, 2007 | 07:11 AM
MaximaSE96's Avatar
Maxima Owner
Old Jan 31, 2007 | 07:54 AM
maxima_kenny96's Avatar
I always use 5, never had a problem.
Old Jan 31, 2007 | 09:22 AM
Q8BallMAXIMA's Avatar
I always use the manual specs. for oil. If you fill it higher than the 4.25 qt, you could potentially blow out seals.
Old Jan 31, 2007 | 09:32 AM
dgeesaman's Avatar
Maintenance Monster
The other reason too much oil is a problem is potential foaming. Foaming in the crankcase will lead to major temperature rise and lubrication problems.
Dave
Old Jan 31, 2007 | 09:58 AM
MaximaSE96's Avatar
Maxima Owner
Diff cars require more...my friends M3 is liek 7 qts or somethig redunkulous
Old Jan 31, 2007 | 11:15 AM
maximafrenzy's Avatar
Fuhget About It.....
When I put in 4.25 it looks like I put too much, also another Maxima friend hipped me to Supertech oil at Walmart, it runs good and is cheap. Any1 care to comment.
Old Jan 31, 2007 | 12:05 PM
Cdg2125's Avatar
The point is that you could have a big problem. If you won't listen to everyone telling you that you can blow the seals then o'well. When it happens then maybe you'll put in 4.25. That's for everyone, not a shot at you or anything.
As for the post from maximafrenzy, you posted your answer. "Cheap" is the only word that matters in that post.
Old Jan 31, 2007 | 12:26 PM
2da mizzax's Avatar
Supertech is actually a good oil. As are their filters.
Old Jan 31, 2007 | 12:44 PM
You think so, I don't use it cause its cheap, what am I saving $10? I do not notice any difference in performance, my car actually rides pretty strong, shiiit it feels like a beast!!!
Old Jan 31, 2007 | 01:17 PM
kcryan's Avatar
Supertech isnt bad, but be aware, you wont notice a difference if i put crap oil in your car, but your car sure will, so thats not a good way to judge oil...nor is its color after X number of miles FYI.
Old Jan 31, 2007 | 01:40 PM
buzpuck11's Avatar
I used to put about 6.5 qts. in my previous car, Subaru SVX, so 4 seems like so little, but it will save me money on oil changes, so I don't mind. Also nice and easy to buy a gallon jug.
Old Jan 31, 2007 | 02:07 PM
Thats the thing my cars performance hasn't changed since I switched from GTX, at least I noticed it feels strong and if the oil was bad it prob. wouldn't. I am not any kind of pro, but I can feel what my baby feels.....
Old Jan 31, 2007 | 02:31 PM
dgeesaman's Avatar
Maintenance Monster
Oil has only a minute effect on horsepower output. The real difference is wear over the long haul.
Dave
Old Jan 31, 2007 | 02:51 PM
Dave
So what your saying is switch to GTX because of better wear for my motor? I've seen many ppl here recommend GTX but I never thought twice, until my buddy sug. supertech, he said its the same but if not better.
Old Jan 31, 2007 | 04:42 PM
dgeesaman's Avatar
Maintenance Monster
I'm not sure why so many people are so wound up about oils. There are many good oils, at all different prices. But each person's idea of 'good' is different. People argue all day long about oils (see bobistheoilguy.com) and either you argue about lab tests (which only apply to real life in a limited way) or they argue about your personal experience, which even with the most experienced people is still scientifically insignificant. About the only thing that is agreed is that pure synthetics are best, but conventionals perform well enough that most people will never see any difference even over the full life of a car. So really it comes down to value and how much you feel like spending.
There are many synthetics out there, and they definitely do better for wear than standard oils. But it's at a price, and the extra cost (especially for oils in the $8-10/qt range) is questionable at best. Among cheaper non-synthetics, I think the difference is very small - Castrol, Valvoline, Quaker State, etc, all make a good oil. They market like crazy to maintain the perception that the differences are big.
As long as you don't use something that is plain wrong for your application, you will have good results. By far it's more important to use the appropriate viscosity and change it regularly than what kind you use.
Dave
Old Jan 31, 2007 | 05:01 PM
MaximamixaM's Avatar
yeah, look at the oilguy website. THey have alot of fanatics that run tests on used oils. Even the cheapies-like supertech-should last 3000 miles and be ok. some of the cheaper ones break down faster and are more worn out after 3000 miles than their peers, but if you change frequently you are ok. Personally, you could change at 2000 miles and be well protected if you wanted to.
The worse thing that you can do for an engine is to start it after a cold start-that's where the majority of the engine wear comes from-but no one's gonna say don't start your engine. And the big key maybe filters-and supertech are better than most-or so they say on the internet.
Old Feb 1, 2007 | 04:43 PM
Crooper_Hedder's Avatar
If the outside temp never gets below 20F, is there any benefit of using 5w30 over 10w30? I always use Castrol GTX + Nissan OEM filters.
Old Feb 1, 2007 | 04:50 PM
jxkim's Avatar
werd. i just did my first oil change since i got my max. started using gtx and oem as well. 10w is thicker so worse for colder temps. i would think maybe using the same 5w every oil change would be better than swithcing back and forth.
