control arm bushings and rack & pinion bracket bushings
Old Jan 30, 2007 | 12:46 PM
Olezhka's Avatar
I just installed my tokico suspension yesterday and went to get an alignment today, but they told e that they can't do it until I replace the Rack & pipion bracket bushings and the lower control arms bushings.
Where can I get these parts cheap and can I do this myself?
they also told me not to get just the control arm bushings, but to get the whole arm because it will last much longer. Is that true?
Old Jan 30, 2007 | 01:14 PM
f550maranello2's Avatar
i would get a new control arm and call it a day because replacing those bushings is a pain in the ***... they are expensive though... i would go to the dealer and get them...
Old Jan 30, 2007 | 02:30 PM
buzpuck11's Avatar
Control arms with new bushings and ball joints are on ebay.
Old Jan 30, 2007 | 02:39 PM
yea and they are CRAP dont buy them!!!!
Old Jan 30, 2007 | 02:46 PM
Gismo-T's Avatar
B!tch We Got a Problem
e-bay ball joints & bushings are garbage! Many members have had problems with them. I'f your going to get control arms, get them from World Parts Express..... genuine Nissan parts. Much cheaper than the stealership!
Old Jan 30, 2007 | 02:51 PM
^^^^ Werd.. cheapest place to get them...
Old Jan 30, 2007 | 02:55 PM
buzpuck11's Avatar
How about rockauto.com control arms? Do any of these ones not on ebay come with ball joints too?
Old Jan 30, 2007 | 02:57 PM
Maxima_Joe's Avatar
4th Gen Parts King
I would just replace the lca bushings with es bushings and moog ball joints while your at it.
I don't see why people think the bushings are difficult to change.I have done 3 pairs of arms and it wasn't difficult at all.
Old Jan 30, 2007 | 03:07 PM
Gismo-T's Avatar
Not saying it's difficult, some people would rather just swap them out.
Which reminds me , still have to do mine.
Old Jan 30, 2007 | 03:48 PM
Olezhka's Avatar
k well now I know where to get the parts, but i dont really know how to actually replace them.
does anyone have a how-to.
for the control arms and also the rack and pinion bracket bushings <--- this is the one I need to replace the m.st
Old Jan 30, 2007 | 04:16 PM
dgeesaman's Avatar
Maintenance Monster
If those bushings are actually shot, then I agree.
The bushings are available seperately in urethane for cheap, but installing them is a major pain. Installing a new balljoint is easy, so if you go this route make sure a new balljoint is put in too.
Well you do get the balljoint with the arm. I don't think buying the whole arem will necessarily last longer, but it will be a lot easier and more comfortable. Urethane bushings need to be greased, and mine squeaked and popped not long after installation when the grease got pushed out. I recently switched to a new pair of OEM control arms and the ride is the same but the noises are gone. Wish I hadn't screwed around with the urethane stuff.
I suspect this shop is taking you for a little ride. Both of these components can fail in practice, but I suggest that they set the alignment close and you go get a second opinion. They could easily rack up a load of labor and parts on this job, and I worry they are trying to do just that.
Dave
Old Jan 31, 2007 | 01:55 AM
Olezhka's Avatar
I don't think that they are "taking me for a ride" because they told me to go get them replaced somewhere else and come back for the alignment.
Also, for our cars do we need to get all 4 wheels aligned or just the 2 front?
Old Jan 31, 2007 | 05:10 AM
maxprivate's Avatar
Black Lion
its just the front two.there is no adjustments to be made in the rear for our car.
Old Jan 31, 2007 | 09:06 AM
there can be but it requires shims and nobody wants to mess with it...
Old Jan 31, 2007 | 09:14 AM
dgeesaman's Avatar
Maintenance Monster
Sounds like they are giving good advice then. These parts do wear out, although most of the time a shop won't tell you to replace both bushings and both control arms. But it's a wise maintenance investment.
The steering rack bushings are a pain to replace because you have to lower the y-pipe to get to the rack bracket bolts. Changing these bushings isn't too hard if you're a DIY'er. Just lower the front end of the y-pipe, remove the heat shield on the passenger side bracket, and match mark the location of the rack against the firewall or something. Then take off the brackets and and slide off the old bushings, slide on the new ones. Line it up to the match marks and reassemble.
The control arms aren't too hard either, but I strongly recommend buying a pair from Nissan directly if you don't go the whole urethane bushing route. $150/ea from www.worldpartsexpress.com. This one is also DIY but requires a hefty impact wrench. A shop should be able to change both in about an hour.
I'll bet when it's all done it will handle like a whole different car.
Dave
Old Jan 31, 2007 | 12:33 PM
Olezhka's Avatar
Thanks a lot Dave, thats what I needed to know.
Old Jan 31, 2007 | 01:47 PM
buzpuck11's Avatar
Do the control arms from worldpartsexpress come with ball joints? If they don't do you have to get new ball joints pressed into the lca?
Old Jan 31, 2007 | 02:28 PM
dgeesaman's Avatar
Maintenance Monster
Yes, the OEM control arms all come with balljoints in them.
Old Feb 1, 2007 | 05:38 AM
njmaxseltd's Avatar
A four wheel thrust angle alignment is the correct way to align a car.
Indeed there are no adjustments in the rear, but the front end must be aligned to the rear (thrust angle) to assure straight tracking and a perfectly centered steering wheel.
It's also nice to see the rear tracking numbers to be sure it's within spec as well.
Old Feb 4, 2007 | 02:51 PM
Olezhka's Avatar
so the rack and pinion bracket bushings are called steering rack bushings?
Where can I get these? I can't find them anywhere
Old Feb 4, 2007 | 05:36 PM
pmohr's Avatar
No more Maximas...
Hunter shows no rear adjustments, shims or not (three different software revisions, too). Toe and camber only adjustable by bending the beam, caster is set permanently.
Old Mar 15, 2007 | 05:41 PM
BORQUA79's Avatar
nycmaximas member
I have the same problem with my car. I also went to get an alignment and it wasnt perfect but close... The machanic told me that I needed the rack bushings as well. I saw that it was all braking apart. Both of my CV Boots we ripped so he said that I needed both axles replaced. He said that since I was there might as well replace my lower control arms also??? Thats 1200 in parts alone...
But would ripped boots mean that I need new axles????
Old Mar 15, 2007 | 07:10 PM
buzpuck11's Avatar
Most of the time torn boots mean its time for new axles, unless they JUST tore recently and the grease is still intact, then you can get new boots and repack the grease. Otherwise, the grease spins out, dirt and pebbles get in the boot and mix with the grease and wear out the joints like sandpaper with every rotation.
Old Mar 16, 2007 | 06:23 PM
BORQUA79's Avatar
nycmaximas member
I see... I guess its about time?? 140,000 miles I am quoted at $1000 for the job
replace both axles, both lower control arms and rack bushing... Is that a good price?
knight_yyz
Nov 1, 2015 01:34 PM
tseng1023
Oct 15, 2015 08:30 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
