Engine painting
Old Jul 5, 2001 | 08:17 AM
klubjunkee's Avatar
Alright, I dunno how to explain what I want to do since I don't know the exact names given for the parts so bare with me. I want to paint my engine, not the plastic cover piece but the engine itself. I removed like 9 lugs and 2 hoses but I still can't seem to budge it. Are there any other lugs I have to remove. I took off 8 that was visible and 1 more after I removed the plastic cover. Am I missing one or what? Please help, I don't want to have to put it back togeather and take it apart again so any prompt info would be great.
Old Jul 5, 2001 | 11:20 AM
mzmtg's Avatar
Minister of Silly Walks
Sorry dude. You're gonna have to be WAY more specific than that...
Old Jul 5, 2001 | 12:09 PM
MegaMax's Avatar
What Parts..?
Use this Pic... What do you want to Paint..!
Old Jul 6, 2001 | 09:07 AM
klubjunkee's Avatar
More specific
Here's what I'm looking @ painting
Old Jul 6, 2001 | 09:35 AM
Albertt's Avatar
klubjunkee: What you're looking to paint is called the valve cover. >>
It's made of cast aluminum. In my opinion, it would nicer if you powdercoated it. If you really want to go the painting route, I would suggest you have it media blasted to clean and rough up the surface. Then use one of the high temp VHT paints to apply color.
Old Jul 6, 2001 | 10:06 AM
klubjunkee's Avatar
Re: klubjunkee: What you're looking to paint is called the valve cover. >>
What's a rough estimate for powder coating? I have the VHT High temp paint, but is there a cheaper alternative to prep it for painting. Also, I still can't remove it.
Old Jul 6, 2001 | 11:30 AM
Albertt's Avatar
Valve cover >>
Removing the valve cover...never done it myself...but I'm sure someone here has before...should be some bolts thats all. I'm not sure, but I think that you might have to remove the spark plug/coils too.
An alternative to media blast would be to hand sand the valve covers yourself. But you must be really careful, you don't want to gouge the aluminum...or remove too much. If you don't clean and rough up the surface, the paint won't adhere well to the cover.
Where are you located? I know of two places that perform powder coating...they are both located in Connecticut.
Old Jul 6, 2001 | 01:13 PM
Whitemax's Avatar
Disco Biscuit
Are you wanting to paint the metal, or the plasitc piece that covers the spark plugs?
Old Jul 7, 2001 | 07:43 AM
klubjunkee's Avatar
The plastic spark cover peice I already painted. I'm looking @ painting the metal part behind. Look @ the attachment above.
Old Jul 7, 2001 | 07:46 AM
Krash513's Avatar
i gotta ask ya where ya got the neon for your dash, i havent a clue where to look.
Old Jul 7, 2001 | 08:08 AM
klubjunkee's Avatar
Neon
Try asking @ your tuner shops for Verad neon cables or Streetglow hotwirez. You can also check ebay.com
Old Jul 7, 2001 | 08:09 AM
Whitemax's Avatar
Disco Biscuit
Just making sure.......
Old Jul 7, 2001 | 06:23 PM
gabuchu's Avatar
Underneath each bolt that you removed, there should be a rubber and a metal thing. You have to take these out. Also the coils need to come out. Gently pry it up. It shouldn't take much force.
Old Jul 7, 2001 | 07:40 PM
sinewave's Avatar
Mine was stuck on pretty good. I had to use a plastic dead-blow hammer to knock it loose. You could probably tap it loose with a hammer and a wooden block. Of course it goes without saying, double check that ALL of the bolts are removed. Also, FWIW, the gasket is th re-usable type.
Old Jul 8, 2001 | 01:02 AM
Nismo's Avatar
can this be annodized instead?
shilov
Feb 19, 2024 09:40 PM
seesole
Sep 14, 2015 12:38 PM
16_SR
Sep 9, 2015 07:14 PM
Hdnseek
Sep 9, 2015 05:55 AM
