timing chain
Old Jul 5, 2001 | 10:07 AM
loudmaxima's Avatar
anyone know about how long of a job this would be?- for mildly experienced mechanic (3 years, couple complete rebuilds) , no access to a lift.. so ill be using floor jacks/stands ..
is there anything else i should check , or replace , while i have it a little apart- plan on replacing belt, and hoses - im looking at about 120k miles , almost positive nothings been replaced- should i look into water pump?
~also ,all i have is the large chilton manual for 1995-1999 imports which shows how everything comes off nice-and all the sprockets markings,where to be lined up etc.. but it goes into replacing sprockets and all that stuff, should i just use it and just take off what seems to be in the way? or get a good book for the specific project?
Old Jul 5, 2001 | 11:11 AM
mzmtg's Avatar
Minister of Silly Walks
You dont need to replace your timing chain(s). They last the life of the car.
There that was simple...
Old Jul 5, 2001 | 11:32 AM
Daniel B. Martin's Avatar
The Chilton repair manual for the '93-'98 Maxima has good coverage for this job. However, are you sure you need to do this? What symptoms does the engine exhibit?
Old Jul 5, 2001 | 11:50 AM
loudmaxima's Avatar
welllll...im setting a weekend aside to just do maintance , which i've neglected ... i need to do cv-joints - serp. belt- all fluids- plugs
the only problem i have is just on start ups it just cranks over and over - the only other thing im thinking about is the fuel pump, you can hear like the whine/buzz pretty bad
Old Jul 5, 2001 | 11:59 AM
Sonic's Avatar
What year is your car? The '95s have notoriously weak and problematic starters.
Old Jul 5, 2001 | 12:23 PM
loudmaxima's Avatar
it is a 95...
Old Jul 5, 2001 | 03:23 PM
Leave it alone
There is no recommended service interval for a timing chain. You replace it when it becomes loose and noisy. Timing chains are durable, and a loose chain is uncommon.
Timing chains tend to fail slowly. A worn chain will emit an ugly rattling sound, most pronounced immediately after engine start-up. It can go on like this for thousands of miles, slowly getting worse, before it breaks. Therefore you have a lot of warning before bad things happen.
You report no symptoms of a loose timing chain so leave it alone!
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
