Mesh Grilles, Help Find Me One
I have a question, where do you guys get the custome mesh grilles and inserts for the front grille and bumper, i have a 1996 maxima and have been looking for weeks for one and cannot find one, can any of you guys help out
http://cgi.ebay.com/ebaymotors/aw-cg...item=593016421
is that how you got yours? I want to know, some ppl do it on their own and i would like to know how, can someone give me a set or instructions with everything i need to do it and of how to do it
thanks i really appreciate it
student in dire need of ghettoing his car
Sorry to be annoying but im sorta new at this and really want one, when you say glue it in or tie strap it in, what do u mean, where would i glue it into and tie strap it to where, if i do tie strap it, wouldnt u see the tie straps?
also after u cut them, u sanded the edges?
could u possibly bend the edges in and buy metal wire to put around the cut out piece and put it in like that?
also one last question, how do u take out the crappy grille that came standard with the maxima, i dont want to replace the whole thing, i just want to take out that plastic thing that has the nissan sign on it and put mesh in their too
thanks so much, i really appreciate this
newbie steve
newbie steve
Originally posted by Ravq
If you are referring to my grill it came like that. It's a Stillen grill. But if you are referring to the lower inserts (in the bumper) I used to have a set that I made out of rain gutter mesh that I cut to fit and had glued and strapped into the bumper. I did a poor job of cutting them and sanding them so the sharp edges started to scratch the paint so I removed them. It's very easy to do. Just buy the mesh and trace an outline on it and cut and sand it. You can either glue it in or tie strap it in. That's what the guy from eBay is selling. Already prepped mesh ready to slap on.
newbie steve
newbie steve
If you search for grill or gutter mesh you'll turn up a lot more info. You may even find that guy I was referring to:
http://forums.maxima.org/showthread....ighlight=grill
RE: Gutter Mesh Grill
I just finished my gutter-mesh grill, and it looks alright. The best thing to do is try and make a stencil, and where it won't fit/is scratching the grill, trim it. You can tie it in using garbage ties (cut off the white part so it is all silver). By using the garbage tires, you will have strong support that you cannot see because it is so thin and silver. I found that the bumper insert just stayed in there (make the fit a little tight). I'm sure you will scratch the bumper a little (not cursing you), and this is normal. You will also gash the sh*t out of your hand, and this is normal as well. For looks, you don;t want to leace the Nissan symbol under the mesh, so gently pry it off (I used a flat-head screwdriver) and you will be able to super glue it to the mesh. This will give a nice clean look, like it was professionaly done. You can super glue the mesh in, but I wouldn't do that, so that if you screw up you can take it off. I didn't trim mine too well, and I might have to get another gutter sheet and do it over (they're so cheap I don't even care). You might have to do this too, so don't worry. The sheets are under $2 each, and I believe that at Home Depot their real name is a "gutter guard". The are silver and about 20"x8x (a very good fit). If you know anyone who is good with arts and crafts, I would let them do it for you, because you will get a nicer fit. It is supposed to be easy, but I honestly found it a little hard. It took me about 2 hours, but I didn't do such a great job (trimmed a little too far in certain areas around the rim). Good luck - its a cheap method that should work if you take you time and are willing to buy more gutter sheets to perfect your work. Just trying to help.
I just came across another post about the grill inserts and Yellowbrother who has a sig pic with the mesh inserts that I thought you mind want to see.
http://216.122.219.59/forums/showthr...threadid=51195
What type of glue do u use
what type of glue do you use to keep teh mesh grille in place. do i need a special tool to cut the mesh? also do you know if anybody sells chrome mesh, i really want a chrome mesh grille
also thanks very much for all of your help on this issue, i really appreciate it.
Re: What type of glue do u use
adamgalazka
Feb 5, 2023 08:24 AM
pears
Sep 18, 2015 05:25 AM
