Timing chain question???
Old Feb 1, 2007 | 10:01 PM
WhiteMaxima9600's Avatar
I read somewhere that the VQ engines do not require the replacement of the timing chains. I currently have 181,000+ miles on my 96 with the stock chains. Is this true that they do not ever need replacing?? I appreciate it guys
Old Feb 2, 2007 | 04:26 AM
jltibbs's Avatar
i had mine replaced last year cause of the rattle. i got a hell of a deal on parts AND labor. thats the main reason why i did it.
Old Feb 2, 2007 | 10:02 AM
Anyone else want to chime in?
Old Feb 2, 2007 | 10:12 AM
sky jumper
you might get more responses if you take down the middle finger gremlin. not many people like to be flipped off by those asking for help.
Old Feb 2, 2007 | 01:35 PM
99BlackMaxMS's Avatar
Unless it is making excessive noise, there is no real need to replace it. They are made to last the life of the engine. When you start to hear noise, it could hint to you that the chain is starting to go.
Old Feb 2, 2007 | 02:11 PM
95GLEMAXX's Avatar
nissan recommeneds you change it at 100k and 200k. im changing my water pump b/c it is leaking, so i figured i might as well do the timing chain while i got that side of the engine apart, but i mean if its not making noise, then theoretically you dont HAVE to change it, but 181k is a lot, so you should prob consider it soon.
Old Feb 2, 2007 | 04:49 PM
Sounbwoy's Avatar
265,xxx- original everything....except for the transmission...
Old Feb 2, 2007 | 06:00 PM
nismology's Avatar
The chain itself doesn't need to replaced. The tensioner and guide will need to be though.
Old Feb 2, 2007 | 09:09 PM
ray_289's Avatar
my car makes a whining sound where the timing belt is. Could it be that the tensioner is bad?
thanks
Old Feb 2, 2007 | 09:54 PM
Dang, sorry guys for the middle finger guy, I really did not even notice that! Thanks for your inputs though.
maxinout93
Oct 27, 2015 01:29 PM
max_speed97
Aug 26, 2015 07:46 PM
doobadoo
Aug 15, 2015 06:43 PM
wingnut2006
Aug 15, 2015 04:16 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
