Thinking of PS turkey baser flush and fill like 4 times, which ATF to use?
Old Feb 6, 2007 | 01:07 PM
andrei3333's Avatar
I do not have any problems with steering but this costs 10 dollars so why not ?!
I saw several ATF fluids at a nearby wal-mart, a brand called tech2000 (i think) i never heard of it, i saw Valvoline ATF, and Valvoline High mileage ATF.
They are all Dexron III but which one is best for PS ?
The high mileage ATF states it has some detergents in it to help clean the system or something like that. i am leaning against this as i dont want detergents in my PS. Deciding between brand names and cheapest brand i never heard of is kinda tricky.
Old Feb 6, 2007 | 01:40 PM
metal_god98SE's Avatar
You;re right....Dexron III is the proper fluid for power steering in the Max. I would agree with your thoughts to stay away from the detergents in the "high mileage" ATF. Maybe it would be best to use a good quality Dexron ATF and stick with it
Old Feb 6, 2007 | 01:44 PM
heynow's Avatar
Just go with Mobil 1 Synthetic ATF. That's what i used to change my ATF with as well as the power steering. Works well, a HQ product!
Just make sure you disconnect the hoses going into the reservour so that you can get rid of more old fluid!
Old Feb 6, 2007 | 01:56 PM
andrei3333's Avatar
I dont know about synthetic Mobil 1, switching to synthetic this late in the game (209 KM) could prove to be a mistake, since i am going to be mixing old and new fluid i rather stick to regular Dexron III, but which brand name is best for my PS application ? (I have pretty much ruled out any type of oil dubbed "high milage" for their additive package)
Old Feb 6, 2007 | 02:02 PM
sky jumper
use the cheapest DexIII you can find. you will see no benefit using expensive ATF in P/S. it will cost you $2 to do it 5 times.
Old Feb 6, 2007 | 02:05 PM
andrei3333's Avatar
how large is the PS reseviour ? how much fluid do i need to do this like 4 - 5 times ? and how often to do this ( say every 50 to 100 KM is ok ? )
Old Feb 6, 2007 | 02:08 PM
sky jumper
I do it at every oil change. you can only suck out about 6-8 ounces at a time. then top off with fresh, and do it again at your next oil change. or if it's really dirty do it a few times in a row with 50 miles of driving in between, and then do it every oil change. you get the idea...
Old Feb 6, 2007 | 02:11 PM
andrei3333's Avatar
what do u do with the old fluid ? i dont want to flush it down the drain lol can it be recycled ? (but i dont want to pay anyone to recycle it im a cheapo!)
when u replace the fluid like this do u actually feel any difference in steering ? or this is just preventative maintenance ?
Old Feb 6, 2007 | 02:16 PM
sky jumper
in the states you recycle it just like used motor oil. not sure about CAN.
oh, and no - you won't feel any difference, unless maybe you had problems to begin with. just preventative maintenance.
Old Feb 6, 2007 | 02:26 PM
andrei3333's Avatar
Got it. im bored so im gona run to wal-mart and get some cheapo ATF and a turkey baster, let the christmas begin!
Old Feb 6, 2007 | 03:15 PM
Sounbwoy's Avatar
Wow. You change PS at every oil change?
Old Feb 6, 2007 | 03:20 PM
sky jumper
well, kinda sorta. I'm not sure what the total system capacity is, but I'm guessing about 2-3 quarts. so a 6oz drain/fill is not really a change. I reason if you do it every 5k miles it will stay fresh. and it's quick, cheap, and easy to do, so why not? better than changing out a steering rack.
Old Feb 6, 2007 | 03:26 PM
Fr33way™'s Avatar
Wild for Width
You can drain the reservoir and refill a few times over the next few months and have totally new fluid.
Old Feb 6, 2007 | 03:37 PM
Sounbwoy's Avatar
I hear ya. I'll check once in a while but I've never ever changed mine...
rbuswell
Nov 17, 2016 04:54 AM
JoshG
21
Sep 4, 2015 09:04 PM
mclasser
Aug 23, 2015 09:32 PM
doobadoo
Aug 15, 2015 06:43 PM
RealityCheck
Aug 5, 2015 06:18 AM
