Brake pedal won't depress when cold!?
Old Feb 7, 2007 | 05:57 AM
chrisZ's Avatar
Hi all,
My '96 Max has a braking problem. The issue is when very cold like -20C, and the car sits overnight outside, after the car starts and I wish to back out of the driveway, I can't depress the brake pedal to stop. It seems frozen. I keep pressing on the brake pedal about 5 to 10 times (hard) and it eventually releases and works fine for the rest of the day. Now its a ritual during very cold mornings, I just start the car, leave it in park, and press the pedal until it releases. I have flushed the brake fluid twice over the past year and it does look clean. I don't believe there is any moisture in the brake system, but I'm not sure what else it can be. Any ideas...?
Old Feb 7, 2007 | 06:03 AM
Pieps's Avatar
What type of brake fluid are you using?
Old Feb 7, 2007 | 06:10 AM
chrisZ's Avatar
What ever the owner's manual recommends. I believe its Dot 3.
Old Feb 7, 2007 | 08:44 AM
heynow's Avatar
I only got that once this winter, but it nearly caused me to hit a parked car (not cool!) But depressing it a 2nd time loosened it up and i haven't had that happen again. It happened when i didn't let the car warm-up!!! From then on, i let i warm up for a least 3 minutes and i haven't had any issues. BTW, On that occasion, the steering was hard to turn as well (i have fresh ATF in there). JUST LET THE CAR WARM UP ABIT!!!
imported_Nismo_max
Sep 20, 2015 08:19 AM
hozay99
Sep 19, 2015 10:20 PM
ef9
Sep 10, 2015 10:35 PM
jcvgn
Sep 10, 2015 08:03 PM
