Check Engine Light Came on....
Old Feb 7, 2007 | 08:24 PM
Racer_M's Avatar
You know how I do....
Now before anyone gets their panties in a bunch and tells me to read the stickies, hear me out. This problem is of my own making, but maybe you guys can offer a solution.
I bought a 98 max last year. This max had a de-k in there. The check engine light came on about a month ago, and I really haven't driven it since, but the light will not go away. I took it two places to diagnose the problem, including a maxima dealership, and both told me the only code that came up is a "wrong engine" code.
I want to pull the codes from the ecu, but how accurate are the codes if there is a different engine in the car.
Mechanically nothing seems wrong with the car to me, or to the mechanics who looked at it for me.
Anybody know how I can find out what is wrong with it. Can I pull the codes. I'm hoping its something simple like the o2 sensor, but I don't want to spend unnecessary amounts of money.
I went into the "all motor" forum, and posted this several weeks ago, but I didn't get a response.
Old Feb 7, 2007 | 09:14 PM
Cdg2125's Avatar
well if you have a de-k and the code is a wrong engine code then it's probably right. If the car runs fine then don't worry about it.
Old Feb 7, 2007 | 09:31 PM
ComradeJew's Avatar
Side note - what is DE-K?
Old Feb 7, 2007 | 10:06 PM
kdaullary's Avatar
[QUOTE=ComradeJew]Side note - what is DE-K?[/QUOTE
the de-k is the 222hp dohc timing chain drivin 3.0L they used in the 2000 - 2001 max's
wich is obviously not available in a stock 98
Racer_M's Avatar
Well I have to get it inspected soon, and I'm afraid I won't pass inspection with a check engine code.
VQ30DE-K is a 00-01 maxima engine
On a side note, I think I need a new starter...terrible screeching noise when starting on cold mornings, almost sounds like a kazoo, or a stiffled cough...I don't think the starter would cause the check engine light to come up. Would the AC not working cause the engine light to come on?
Old Feb 7, 2007 | 10:25 PM
kdaullary's Avatar
no the a/c not working will not trip a mil, your screech noise is only on start up? when really cold ? and its just for a second right? most likely the power steering pump. seing this a lot right now
Old Feb 7, 2007 | 10:42 PM
Racer_M's Avatar
yes it could be that, because i notice it is a little hard to steer if i dont let the car warm up entirely. the steering becomes very "jerky".
Old Feb 7, 2007 | 10:46 PM
MDeezy's Avatar
"wrong engine code"
you'd got to be kidding. . .
Old Feb 7, 2007 | 10:55 PM
Racer_M's Avatar
Originally Posted by MDeezy
"wrong engine code"
What's wrong with that?
Old Feb 8, 2007 | 01:02 PM
Scruit's Avatar
U wanna try me young boy?
If *I* was going to swap in a newer engine then I'd be swapping in the newer computer and matchign the harness too. Never heard of "wrong engine" code - wonder if they were winding you up?
Old Feb 8, 2007 | 04:21 PM
Cdg2125's Avatar
Havnt seen anyone switch ecu's. Not even sure you can do that. And I don't know how inspections are in PA. You'll have to find out if the de-k will allow you to pass.
Your power steering fluid is cold in the cold weather. Thats why it's hard to steer when the car is cold...
Old Feb 8, 2007 | 05:25 PM
maximafrenzy's Avatar
Fuhget About It.....
How close are you to Youngstown, OH? If you have friends or family go register there, no echeck, thats how I get by with my ecu lights.
Old Feb 8, 2007 | 06:09 PM
gen4maxima536's Avatar
even though you didn't want to hear this, read the sticky and pull the codes and post them here and after that we'll be able to help you more
Old Feb 8, 2007 | 09:17 PM
95_Maxima_5spd's Avatar
try resetting the ECU?
Old Feb 11, 2007 | 08:59 AM
Racer_M's Avatar
I reset the ecu and the code came back a day later.
I have a code 0505, which is
0505
No Failure Recorded/Detected
wtf
Old Feb 11, 2007 | 09:49 AM
2da mizzax's Avatar
From what i remember that code means nothing is wrong but can be triggered by a voltage
surge/drop. I could be wrong on this, but how old is your battery?
Old Feb 11, 2007 | 09:51 AM
Racer_M's Avatar
5-6 months old
Old Feb 11, 2007 | 10:15 AM
Kevlo911's Avatar
Kevlo for President
Lol you gotta be kidding me. Go to autozone and see what PXXXX code comes up.
Old Feb 11, 2007 | 10:19 AM
2da mizzax's Avatar
well, my aunt had 0505. I reset it and it never came back. so reset it using the method in the link i PM'd you with and hopefully it wont return. But go to AZ first and see what they pull.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
