anyone have directions for rewiring the clearance lights for a 95 maxi?
Old Jul 5, 2001 | 07:38 PM
alloutmax's Avatar
i need instructions for rewiring the lights next to the headlights so the will be always on 27 watts> thanks
Old Jul 5, 2001 | 07:57 PM
nelzavala's Avatar
Better solution instead of snipping your factory wires!
I was going to rewire my corners but instead of doing that you remove the bulb, find the **** on the side that is nearest the glass( there are two ***** on the sides find the one near the top)then take a nail clipper and snip it. place the bulb back in and now you should be able to turn it in the opposite direction. By doing this you should be able to get a brighter look and if you chose to go back to the stock look you only have to change the bulb. If it doesn't make sense to you write me. this should take 5minutes to do.
Old Jul 5, 2001 | 08:14 PM
Sprint's Avatar
http://maximanorth.homestead.com/fil..._mods_rwcl.htm
Old Jul 6, 2001 | 06:14 PM
Vyrus's Avatar
LISTEN TO SPRINTMAX!
I read this post this morning and went to Sprintmax's link. The direction were perfect and I did them this morning (July 6th). The lights are 27 watts all the time, and VERY BRIGHT! The only other this you need to know is that there is a hook-type thing towards the outer side of the car that makes it hard to come out. One you pull that out, you will see a little piece of a bar (inner side) preventing you from pulling the light out. Put a flat-head on the bar and turn the flat-head so that the piece pops out of the socket (you will see what I mean when you are there). I reccomend using a flat-head to get the lights out. I did it this morning and they work great! Thanks Sprintmax! If you have any questions feel free to leave me a message or eMail and I will get back to you the same day! Just trying to help.
Old Oct 25, 2001 | 09:36 PM
kibic's Avatar
Re: LISTEN TO SPRINTMAX!
I tried to g to the page but something's wron with it, can you give me directions on rewireing corner lights for 95, (you posted a wile ago) THANKS
Old Oct 25, 2001 | 09:40 PM
multiplexor's Avatar
Sprint it says access to the site has been temporarily suspended...
Old Oct 26, 2001 | 05:50 AM
njmaxseltd's Avatar
Turn the bulb around
Your wasting your time rewiring your car. Pull the bulb out of it's socket, snip the top notch off, turn the bulb 180 deg. and put it back in. Takes less then 5 min. to do both sides.
lowpost99
Oct 26, 2025 06:53 PM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
