Steam from behind the engine
Old Feb 12, 2007 | 01:25 PM
Olezhka's Avatar
I noticed that my car is steaming from behind the engine
Heres a pic, you can't see it, but it's there.
The red arrows show where its comming from
What could this be?
Old Feb 12, 2007 | 01:45 PM
Ceasars Chariot's Avatar
Old Maxima Legend
have you done any work on the car ? after we swapped the usim for the oovi, mine was steaming from that area. we figured it was oil or moisture of some sort. looked with a flash light and smelt around and kept letting it run and it eventually faded away.
have a look with a flashlight or some light source and see what you can find.
Old Feb 12, 2007 | 03:00 PM
foxracing12's Avatar
heat up the engine till it gets hot and starts steaming, then grab a little inspection mirror and a flashlight and look behind there. check the area around the valve cover, head, and any other place where fluids can leak and go from there.
Old Feb 12, 2007 | 04:16 PM
Muyrec's Avatar
Rear Valve cover gasket is borked. Replace that and while you're at it, Change the spark plug tube seals in the rear as well. Mines was doing the same thing untill i replaced those items.
Old Feb 12, 2007 | 07:13 PM
venompwr2's Avatar
One of mine is doing the same thing, havent determined the problem yet.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
